Wix fuel filter
Old Mar 30, 2014 | 01:30 AM
_zebra's Avatar
_zebra
Default Wix fuel filter
Anybody have any problems running Wix fuel filters on your cars?
I assume they'd be just as good as the rest of the stuff they make but just wanted to be sure it wasn't the red-headed step child of the Wix family.
Also, for those who ordered off rockauto, did you get the right part?
I've typically heard good stuff about them and only started to question it when I used their site to look up the part number for an MG5 bellhousing on a 2006 Yukon with a 6.0. (For those of you not familiar with trucks, there's 2 things wrong with that search - 3 if you count the part number it gave)
Old Mar 30, 2014 | 12:52 PM
GeneT's Avatar
GeneT
Wix makes filters for almost everyone else. I replaced my fuel filter/regulator with a Wix from R.A. Cost about 1/3 what an AC/Delco one was at the dealer, and I believe the AC/D is made by Wix.
Old Mar 30, 2014 | 02:30 PM
Cybermind's Avatar
Cybermind
The Wix filter and the AC Delco are the same. Use the Wix fuel filter with confidence since it is OEM.
Old Mar 30, 2014 | 02:49 PM
_zebra's Avatar
_zebra
so the part # on RA is correct, then?
Old Mar 31, 2014 | 07:09 AM
Cybermind's Avatar
Cybermind
I can't comment on whether the Rock Auto part number is correct but you can go on the Wix website to confirm the right Wix part number. Please keep in mind that the same fuel filter may be specified for several different GM cars and trucks.
Old Mar 31, 2014 | 10:31 AM
Dcollins3208's Avatar
Dcollins3208
This thread just saved me about $60.
Old Mar 31, 2014 | 01:11 PM
_zebra's Avatar
_zebra
that's another reason i started it
Old Mar 31, 2014 | 01:34 PM
Dcollins3208
I just ordered one, pt# 33737 per RA. If you haven't already bought one I'll let you know how it fits when it comes in. I've been doing routine maintenance on the car lately and one of the next items on my list was the fuel filter. $100 seemed a little steep so I'm glad I saw this
Old Mar 31, 2014 | 01:35 PM
TastyBacon's Avatar
TastyBacon
Yes, right part, right part number, right price from RockAuto. Zero problems.
Old Mar 31, 2014 | 01:45 PM
_zebra's Avatar
_zebra
cool. i ain't in no hurry, though... it was 65 on Sat when i was working on the car & truck, but now it's 19 with 40mph blowing snow/ice again. i won't be changing this part any time soon.
Old Mar 31, 2014 | 01:50 PM
Chicago1's Avatar
Chicago1
I just ordered one from O'Reilys an hour ago it was 30 something close to 40 bucks.
Old Mar 31, 2014 | 02:44 PM
strand rider's Avatar
strand rider
In reality, is a fuel filter losing flow a big deal?
I am not questioning the benefits of good maintenance. I am asking about my situation, with a car that has a list of corrections, hopefully in a logical progression . Since I live in a location with only clean gas, and gasoline is a solvent, I am thinking to schedule this as a finishing touch, I don't have the owners manual that would contain a maintenance schedule.
Funny thing is, I am often posting about the foolishness of trying to out think the original engineering. Is there a complexity to this situation I am missing?
I was thinking of renewing the parts in that area when I correct my fuel transfer jet problem. Am I correct to consider this filter in this way, or is there an experience I don't foresee. It's the labor , and working around fuel that leads me to put this toward the end of the task list. JUst checking to see if my understanding is reasonable.
Old Mar 31, 2014 | 03:00 PM
Dcollins3208
Originally Posted by strand rider
In reality, is a fuel filter losing flow a big deal? I am not questioning the benefits of good maintenance. I am asking about my situation, with a car that has a list of corrections, hopefully in a logical progression . Since I live in a location with only clean gas, and gasoline is a solvent, I am thinking to schedule this as a finishing touch, I don't have the owners manual that would contain a maintenance schedule. Funny thing is, I am often posting about the foolishness of trying to out think the original engineering. Is there a complexity to this situation I am missing? I was thinking of renewing the parts in that area when I correct my fuel transfer jet problem. Am I correct to consider this filter in this way, or is there an experience I don't foresee. It's the labor , and working around fuel that leads me to put this toward the end of the task list. JUst checking to see if my understanding is reasonable.
A clogged fuel filter is fairly common actually. Mine is more preventative maintenance, but if your filter is clogged it will cause the fuel pump to work harder thus ruining your pump. Replacing something cheap as preventative maintenance can save a couple hundred by saving the fuel pump. Changing the filter is pretty straight forward
Old Mar 31, 2014 | 06:47 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I agree, but A) I found that the ethanol content in many brands of gas today, will deteriorate the O-rings in the inlet and outlet sides of the filter prematurely; and B) Unless you have the car on a lift, changing the filter is awkward, at best.
My C-5 is an '01, and I replaced the filter when the car was 3 years old, just as good maintenance. In 2012, I had to change it again, as one of the O-rings had gone bad, and it was dripping gas....right on to the exhaust pipe, which is directly under the fuel filter. At this point, the car has 22-23,000 miles......
Old Mar 31, 2014 | 09:03 PM
Dcollins3208
Originally Posted by leadfoot4
I agree, but A) I found that the ethanol content in many brands of gas today, will deteriorate the O-rings in the inlet and outlet sides of the filter prematurely; and B) Unless you have the car on a lift, changing the filter is awkward, at best. My C-5 is an '01, and I replaced the filter when the car was 3 years old, just as good maintenance. In 2012, I had to change it again, as one of the O-rings had gone bad, and it was dripping gas....right on to the exhaust pipe, which is directly under the fuel filter. At this point, the car has 22-23,000 miles......
Yikes, and yes doing anything with these cars without a lift is a pain in the a$$
Old Mar 31, 2014 | 09:08 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I have no problem using any of the WIX products on any of my cars.
Old Mar 31, 2014 | 10:54 PM
95wht6spd's Avatar
95wht6spd
How often should these be changed? I should probably do mine, since probably never done. I will research how to change, unless someone has a good how to link?
To Wix fuel filter
Old Mar 31, 2014 | 10:59 PM
Dcollins3208
http://www.corvettelegends.net/html/...eplacement.doc
Old Mar 31, 2014 | 11:04 PM
JrRifleCoach
That's great!
Old Mar 31, 2014 | 11:32 PM
racebum's Avatar
racebum
huge deal. it can pop motors
most the time a plugged fuel filter can maintain idle but falls off as more fuel is needed. when that happens the engine goes lean and you hope the knock sensors and 02 readings set a CEL before you burn a hole in a ringland when you spin the motor up
