Having brake and oil Cooling Issues
Old Mar 30, 2014 | 02:15 PM
Xplosive Performance's Avatar
0Xplosive Performance
Former Vendor
St. Jude Donor '13
Default Having brake and oil Cooling Issues
05-13 Corvette C6/ZO6/GS/ZR1 Front Grille Mounted Brake Cooling Duct
XP Motorsports 05-13 Corvette C6/ZO6/ZR1 Front Grille Mounted Brake Cooling Duct System
Everything you need to install grille mounted brake cooling in your C6 Corvette. The ducts fit behind the front grille no need to loose your fog lights. The ducts mount on the inner grille support (triming of the support is required). For ease of installation removal of the front bumper is required.
Kit Includes
(2) Large Brake Duct Vents
(2) Spindle Mount Brake Hose Adapters
(2) 3" Hose Clamps
(10Ft) High Temperature 550 degree Silicon Brake Hose
Mounting Screws
Instructions
https://www.xplosiveperformance.com/...ct_p_3389.html
$273.97
97-12 Corvette C5/C6/C6ZO6/GS Setrab External Oil Cooler Kit -10AN
Upgrade the stock oil cooler to a performance kit.
If you track or race your Corvette High Oil Temps can be a real issue.
We have put together as a kit everything you need to install an upgraded oil cooler to your car.
KIT INCLUDES EVERYTHING YOU NEED.
(1) Setrab Oil Series 9 Cooler
(1) Oil Cooler Mounting Bracket
(2) M22 to AN-10 O ring oil cooler fittings
(3) AN-10 90 degree black fittings
(1) AN-10 120 degree black fitting
(1) Low-Profile Oil Cooler Adapter for LS-Series Engine
(2) Premade AN-10 Stainless Steel Overbraided lines with above fittings installed
All mounting screws and hardware.
Mounts in stock location on ZO6
Mounts in front of Condensor/Radiator
  • All 1997 to present LS-Series engines (Gen III/IV) with rear-sump oil pans including LS1/LS6, LS2, LS3, LS7, L76/L92/L93, LQ4/LQ9, and LSX
  • NOT suitable for front-sump pans such as Pontiac GTO or Holden/Vauxhall Monaro oil pans
  • No more hunting around to find fittings or hose or adapters.
  • This kit handles the cooling for 450-550HP
Note:
For easy of installation removal of front bumper recommended.
