C5 headlight malfunction
Old Apr 9, 2014 | 02:00 PM
Horst Baer's Avatar
Horst Baer
4th Gear
Default C5 headlight malfunction
My left headlight occasionally does not pop up or close down. There is also a clicking noise (solenoid?) from the headlight area for 3-5 seconds after the engine has been turned off. Appreciate any helpful comments. Thanks, Horst
Old Apr 9, 2014 | 04:51 PM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
Maybe the plastic gear is worn.
This anodized aluminum gear repair kit comes with a T bracket to hold the cap better than just gluing it together after replacing the gear.
The brass gear kits don't come with this bracket.
http://www.ebay.com/itm/151259530324...84.m1423.l2649
Old Apr 10, 2014 | 12:32 AM
Horst Baer's Avatar
Horst Baer
4th Gear
Thanks for the recommendation. Will look into the gear as you mentioned. Horst
Old Apr 10, 2014 | 01:19 AM
dubtrub's Avatar
dubtrub
I had the same problem and fixed it with the replacement metal motor gear. It's not too difficult of a task after I found several step by step instructions in Google search as well as YouTube videos. Just type in C5 Corvette headlight motor repair.
Old Apr 10, 2014 | 03:24 AM
Horst Baer's Avatar
Horst Baer
4th Gear
Default C5 Headlight Repair
Thanks for your suggestion. Will follow up.
Horst
To C5 headlight malfunction
