PCM Issues with Modded motor?
Old Apr 10, 2014 | 02:38 PM
mhunter1788's Avatar
mhunter1788
Default PCM Issues with Modded motor?
Has anyone experienced PCM issues when tuning a 1998 C5 with a FAST 102 intake Nick Williams 102 TB, Fast fuel rails. Linginfelter 102 MAF.. 55lb injectors, cam, heads, longtubes, etc?
Old Apr 10, 2014 | 03:31 PM
mhunter1788
Correct I am still running the 98 pcm.
Old Apr 10, 2014 | 04:28 PM
CactusCat's Avatar
CactusCat
mhunter1788, I've got virtually every one of those mods on my 98 except the TB is the 90mm LS2 (ported) and the injectors are the 36lb Ford red tops. I stilll have the 98 PCM as well. I have everything else you asked about, new heads, cam, FAST102, headers, etc... No problems with PCM at all. Car made 430 with my A4 and 3.15 gears. Are you having some issues or was this a general question?
Old Apr 10, 2014 | 10:17 PM
mhunter1788
I'm having idle surge issues
Old Apr 10, 2014 | 10:52 PM
Dcollins3208's Avatar
Dcollins3208
I have no experience but I've seen that the 102 throttle bodies are hard to tune, best to use a tuner who has experience with them
Old Apr 10, 2014 | 11:05 PM
CactusCat's Avatar
CactusCat
I had idle surging issues as well when my mechanic did the engine work. Took a while but found the problem. What was it? 2 of the injectors had not sealed properly. It was creating a vacuum leak. I suspect you'll find a leak somewhere as well. It's not uncommon.
Old Feb 23, 2015 | 09:53 PM
tuckin22's Avatar
tuckin22
Hmm interesting... had to bring this one back from the dead.. have all the same issues here. Plus all the same mods. 102 tb and intake,etc... Mine revs high at times and then wants to die out others. Nothing is done in particular to cause it though.
I will have to check for vacuum leak.
OP, You ever figure out what happened with yours?
To PCM Issues with Modded motor?
