I just swapped my 99 C5 cluster to a Z06 cluster with no issues but the speedometer doesn't go below 15 mph. When you start the car the gauges all look fine. I asked the guy who I bought it from and he has no idea. Anyone heard of this problem?
I was told that the sender is different from the Z06 and that's why it don't work right......makes no sense to me. I know a bunch of guys here did it with no issues.
I know one person who had a similar sticking needle issue with a swapped cluster. He pulled the cluster and removed the cover. He then manually exercised the needle and solved his issue. Worth a try.
When you got the cluster was the needle stuck at 15 MPH or did it happen later?
I had the exact same problem with a replacement cluster on eBay. The needle wouldn't go below 10 mph even with the car turned off. When driving the needle would ready 10 mph faster than I was actually going. My HUD continued to report the correct speed. I found that that speedo motor was bad in my case. I took it all apart and manually exercised the needle and found it was much more difficult to move than the others. What I ended up doing was using my old Z06 needle cluster, DIC board, power supply. and speaker in the ebay cluster. A previous owner had installed red trim rings on the background of the cluster so that was essentially the only piece I used from the ebay cluster. The background. The eBay seller refunded my ~20% of the price and I moved on.
Also in my case the cluster didn't report 10 mph until it was plugged in to the car. Outside of the car it would fall to 0 mph. However even with the car off for several days it would sit @ 10 mph. I believe it is a problem in the motor itself for that needle. I contacted several speedo shops in the south east none could help me with a new motor.
Alone it sat at 0. Once it was plugged into the harness it went up to 15mph and stayed there. Just for the hell of it I swapped the original one back in and it went back to 0. I have a defective cluster that I am sending back.
