LS3 Coils
Old Apr 14, 2014 | 08:43 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Default LS3 Coils
Valve covers and coils
Can you mount LS3 coil brackets and coils on an LS1 valve cover? Or can you mount LS3 valve covers with coil brackets and coils on an LS1 head? Would you need a harness adapter in either case as well?
I have been searching and it seems you can use LS3 coils on an LS1 but I could not find an answer to the preceding questions specifically. Thanks for any information.
Old Apr 14, 2014 | 10:49 AM
JetMechZ16's Avatar
JetMechZ16
Old Apr 14, 2014 | 11:26 AM
3boystoys's Avatar
3boystoys
What's the point? Your old coils malfunctioning??
Old Apr 14, 2014 | 11:43 AM
7LitreC5's Avatar
7LitreC5
You need to use the LS3 coil harness and that will plug right in to the C5 main engine harness.
Old Apr 14, 2014 | 02:49 PM
alxltd1's Avatar
alxltd1
Not what I asked, but fair question. No the LS1 coils are not malfunctioning because I don’t have any coils right now. I do have the LS1 valve covers but also a custom finished pair of Holley coil covers. The coil covers are designed to mount on the LS3 coil brackets and have cutouts spaced for the position and size of the LS3 coils. Hence the questions asked.
Thanks for the info.
To LS3 Coils
