Tips on 04 Diff. REMOVAL
I just did the transmission and rear end on my '02 and like an idiot didn't look at my clutch and now I have to do it all over again.
I have a file with some pretty good guidelines when removing these parts that I can email to you if you want it. It's called Dope's clutch removal. You have to drop the rear carrier ***'y. to get it out, and the car has to be high enough to slide the unit out the back and clear the trunk bottom. I have a 4 post lift so working under the car isn't so challenging. Too bad you don't live closer. We could both learn.
jim '02 Z06
You didnt say why you want to remove the Diff. While you have it out, you might want to consider up grading the internals to C6 ZO6 hardware, You can improve the output shafts, clutches and limited slip belleview springs (which will most likely be cracked)
Here are some killer posts on the whole process. Its fairly easy and doesnt cost to to much compared to the improvement you get!
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
I also included one post on replacing the output shaft seals. That is almost a MUST DO or you will have a leak when you are done...
PS,,, Its also a VERY GOOD picture tutorial on differential removal also. Thought you would enjoy it.
Another NOTE!
I recommend replacing the VENT on top of the differential. The little rubber disk inside gets old and nasty and wont seal or vent properly.
Instead of unclipping the brake lines from the cradle,, (Which is a royal pain in the ***) there are TWO unions (one on each line) that you can easily seperate and the lines stay on the cradle when its removed. Just do a simple rear brake caliper bleed when you are done.
Bill
Make sure that you get a differential gear lube that has the correct clutch slip additive or purchase the additive and add it yourself.
The MN6/MN12 trans takes 3.75 quarts. Actually 4 but you can’t get the last .25 out when you drain it.
jim '02 Z06
