Ghost in Transmission
Old Apr 23, 2014 | 10:53 PM
ehuron's Avatar
ehuron
Default Ghost in Transmission
I have a 98 C5 with auto trans. Shifts normal manualy and in auto mode. When in 4th if I need to add a little speed, it will slip for about 1000 to 1200 rpms or 3 seconds and then grab. If I hit it hard, it grabs no problem. Even if I use the cruise control to upspeed, it will slip the same. With cruise on and going up any kind of grade, where it need to keep speed up it slips the same. Normal auto mode from red light and regular throttle, shifts fine. Only happens when I'm already in 4th (overdrive) and needing to increase speed a little. Floor it, while in 4th, and it grabs fine. Driving me crazy trying to figure it out. If it happened in all shifting in every gear I could probably have a good chance to figure it out. Surely, I'm not the only C5 auto this has happened to. Any ideas out there. Thanks.
Old Apr 24, 2014 | 07:02 AM
Cutlassmaster's Avatar
Cutlassmaster
You say slip but does the RPM's shoot up during that time? It sounds more like a delay of it downshifting or almost a hesitation. Better description will help us help you. Have you used the DIC to pull codes?
Chris
Old Apr 24, 2014 | 07:13 PM
ehuron's Avatar
ehuron
Chris
AS I stated in my thread, rpm's raise 1000 to 1200 for about 3 seconds before it grabs. To me that is not a hesitation, but a slip. The only codes are for my 02 sensors, which I'm sure are burned out because of the headers. Anyway, I've already purchased them to intall when I do the trans service. It only does this exactly the way I described it in my thread. I don't know how I could give a better description. I am going to change the 3-4 selonoid, maybe all of them and the harness. Can't hurt. I was just hoping that someone else has had this weird occurance. But thanks for helping. If you can think of something else, let me know please.
Old Apr 24, 2014 | 11:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like you have a problem with line pressure.
When was the last time you changed the trans fluid and the last time you checked the fluid level the DIFFICULT PROPER WAY???
Is your trans and engine stock, modified and have you ever tuned the PCM?
The longer you let it run this way, the more you are damaging that band .
Call RKT56 Rick Kim (forum sponsor) and discuss the issue with him. He will give you the right guidance.
Bill
Old Apr 25, 2014 | 08:55 PM
ehuron's Avatar
ehuron
Default ghost in transmission
Bill
I just wrote out a long reply and it went away before I hit send. The short, I don't know what RKT56 means. Can you give me a little more?
Old Apr 25, 2014 | 09:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Rick Kim
RKT56
http://rkt56.com
Phone number: 301-257-0930
205 Bucheimer Road, #C
Frederick, MD 21701
Old Apr 25, 2014 | 09:28 PM
ehuron's Avatar
ehuron
Rick Kim
RKT56
http://rkt56.com
Frederick, MD 21701
Got it. Thanks, ehuron
To Ghost in Transmission
