Looking into a C5 and not hearing a lot of good things about the runflats. For those that got rid of them, what do you do if you have a flat since there is no spare or jack in the car?
Fix a Flat?
AAA?
Tow Truck?
Just curious cause it sounds like everybody that has went away from the RunFlats is very pleased with the improved ride and handling.
Thanks,
Mike
Re: Question for those without RunFlats? (Curtis629)
Fix a Flat?
AAA?
Tow Truck?
Thanks,
Mike
If I had to do it over again I would change out the runflats the week I got the car new. There is just no comparison with the Bridgestone S03. I went to Wal Mart and bought a patch kit and 12V air compressor for about $25.00. I also bougt a little jack from C5 Frederik just send him $50.00, in Germany via PayPal.
See: http://forums.corvetteforum.com/zero...=295586&page=1
Folks make it sound easy, but first you have to locate the object in the tire. Try that at night when your by your self. Then you'll need something to lay on since your going to have to get down on the ground to make the repair. Cell phone a AAA are good if there is a facility near by they can tow it to. Then there are horror stories about cars being damaged being pulled up onto the flat-bed by untrained or ill equipped tow truck drivers.
Maybe it's the military in me but I always plan on the worst case, then see how the plan will actually work in the real world. So try this - you and the misses are coming home from a late night dinner wearing appropriate dinner attire, your 30 miles from home, it's 11:30 and you both have to work in the morning and the baby sitter was told you'd have her home by mid-night. Oh did I mention it's raining. DING DING DING the DIC announces low tire pressure in the left rear tire (I chose that as that's closest to moving traffic when you pull onto the shoulder). Now put your plan in motion. You tell me how it'll turn out. I'm betting not good.
But there is a very small percentage of vette owners that will scarifice their safety and security for a little more grip (it's not like the car is a cripple on EMT's all the car mags seem to get it to perform with the best from around the world nicely) or less road noise.
I had a bad experience and the EMT's saved my bacon. In fact I drove the car two days with ZERO pressure while the dealer ordered me a new wheel that was damaged when I hit a rain filled pot hole on the way to work. I kept all my appointments, didn't have to take time off of work and kept my mobility which I cherrish. That tire is still on the car too with 17K miles on it.
But as they say do what your comfortable with. Good luck.
Re: Question for those without RunFlats? (AFVETTE)
Well said Tom. I got rid of the Goodyear EMT's but replaced them with Firestone Firehawk run flats that I like a lot better. The EMT's saved me once also. Another thing to consider is the possibility of the bead of the non runflat breaking down from the rim when the tire goes flat. This happened to me on my Cadillac after I had hit a pot hole in the road. The tire could not be inflated because the bead was no longer sealing against the rim. My fix-a-flat and on board compressor were useless.
Plug kit and AAA card, just incase :lol:
But I ordered my pilot sports from Discount tire direct so I also bought the certificates....if any tire is non repairable from a flat, etc... they will send you a new one for free(you just pay shipping). I like that deal :cheers:
It was about $30 per tire for the certificate
Also...like I said I went with the Pilot sports. Love them so far but only had them on for a couple hundred miles...next friday i'm going to try and get to the track and see if I can lower that 12.98 now withouth the runflats.
Re: Question for those without RunFlats? (USMUSCL)
So you are out late at night and you are dressed to the nines, it is raining and the DIC Yells low air. Hmmmmmm, many here always check the Dopler Radar out before they choose the Vette to drive so my Vette only sees rain on long trips. I myself mostly drive my Vette with the top down so no dress-up for me when I am in the Vette. Now I somehow get caught in that exact situation you describe so.................I pull under a gas station cover, an under pass or a closed bank drive thru. I have lights that have an adjustable base and direct the light where it is needed. I always have window cleaner in my car so you use that to find the leak. If the side wall is cut you are screwed no doubt. There are situations where you are screwed with run flats, esp when you are out of town. You should know that there is a ton of difference from the run flats to some real high performance tires. In the ride, handling, comfort and noise alone, makes it a very good choice. If you have no full size spare, everything else is a compromise :lol: :lol: :seeya :yesnod:
Re: Question for those without RunFlats? (EMDExpress)
In response to Tom and others - I respect your opinions, and everyone makes their own decision, and I don't have a problem with that. But, on the other hand...
I bought a Corvette for the functionality of the car as the finest sports car I can afford. I want as few compromises as I can afford, and the best of everything. It's my toy and hobby. The run-flats are most definitely a compromise. Read the current issue of Motor Trend's test on the BMW 330. It has a new option - Goodyear runflats. Motor Trend reports that the exact same model tested last year went through the slalom 2mph faster than the new EMT's.
Sure, a flat would be a pain. But I have not had to change a tire along the road in about 20 years. In that time I did have to have a one year old car towed twice. Once for a failed fuel pump, once for a failed ignition switch. Sure it was a pain, but it was not a total disaster.
If you don't feel the need for the extra benefits of better tires, then I think you should stick with the run flats. But if you are like me and want to have the best you can, change them and deal with the flat if it ever happens.
Tom
USAF Retired
Tom,
No offense intended as you make some very valid points as to the risks you take with non-runflats. But I have a question for you regarding some of your statements.
Did GM purposely ignore the safety and protection of those who would buy their Z06?...No spare, no runflats...Just a plug kit and compressor!
Just curious as to how you take the intentions of GM since they chose to put performance over safetey of the runflats with their own production of the Z06.
Thanks,
Tom
Re: Question for those without RunFlats? (BAD2BNE)
Thanks,
Tom
I don't get it...I think you just answered your own question. Safety in the non-Z06, Performance in the Z06. The 06 is non-compromise for performance. Nothing weird going on here...two different customer profiles.
Re: Question for those without RunFlats? (C5 StockSwap)
Herein lies the problem. In many cases - including mine - it is not two different customer profiles. There have been many, many posts by people regarding the Z06 vs Coupe/Vert stating that they are for two different types of people. Blah, blah, blah about how the Z06 is the no compromises car. Well, in fact it is a compromise car for many of us. I'd love to have all the good Z06 stuff on a Coupe or vert, but GM has forced us to choose between the two, instead of letting us order the Z06 "option code" on a coupe or vert.
Soooo, guys like me who chose the non-Z06 compromise are trying to upgrade our car as much as practical (and financial) means allow us to. And that is why guys like me know longer have run-flats on our car.
Thanks,
Tom
You make it obvious that you don't get it ;) This thread is about runflat vs non-runflat tires!!. not performance capabilities of any of the C5 models.
That is the safety issue vs performance issue I was referring to.
Take care and be safe.
"Did GM purposely ignore the safety and protection of those who would buy their Z06?...No spare, no runflats...Just a plug kit and compressor!"
you 4got to mention that the zo6 doesn't even warn you if the pressure goes below 25psi. at least we have time to pull over to a safe spot when the DIC warns of low pressure.
i have BF goodrich kd's non-runflats for superior dry traction and i don't drive the vette in the rain, that's why i have a second car. i would never go back to runflats. the way it rides now is just too much better now. you have to outweigh the good, the bad, and the "what ifs"
i carry a patch kit, compressor with lights, flares, and c5 federick's jack as soon as i receive it
