can anyone help asap.
Old Apr 26, 2014 | 01:49 PM
93civEJ1's Avatar
93civEJ1
Default can anyone help asap.
LS6 01 z06 changed cam and springs 238/242 .615 / 610 113+2 and BTR springs.
measured a bit ago with pushrod length checker.
one cylinder was 8 3/4 turns for zero lash
one liked 9 turns for zero lash
one liked 10 1/4 for zero lash
Now i am puzzed why the varience in my measurements..
I come up with lengths at zero lash of 7.275
7.25
7.325
these were all done with each cylinder at TDC....needing help assap as the store with the pushrods closes at 3PM. EST.
Old Apr 26, 2014 | 03:09 PM
93civEJ1's Avatar
93civEJ1
Ok I think I am maybe on to something. Im not sure if I measured cylinder 1 at TDC compression or exhaust stroke...How can I figure that out? So I would measure cylinder one and six at TDC...but how do I know which is a compression and which is at exhaust stroke or does this matter when measuring the pushrod length?
Old Apr 26, 2014 | 03:38 PM
Biotex's Avatar
Biotex
TDC compression stroke, both valves will be closed. If you were to remove the number one spark plug, it will blow out air. So if you can put your thumb over the hole, it will be noticeable.
Old Apr 26, 2014 | 03:48 PM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
When you are on the compression stroke on #1, both valves will be closed. You should be able to rotate the engine a few degrees in either direction and there should be no lift at all. For me this is how I know I am on the "back" of the cam lobe.
Old Apr 26, 2014 | 03:58 PM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
I agree... if the rockers are on and adjusted. If you are only checking for pushrod length and no rockers are installed then there will be air no matter what because the valves will be closed no matter what.
To be very basic....I always adjusted the rockers before manifold install so I can watch the lifters. On the compression stroke as the piston comes up both valves should be closed (both lifters will be down). If the exhaust valve (lifter is moving up) is open as the piston goes up then you are on the exhause stroke and soon after the piston reaches the top then the intake will open as the piston goes down and should be closed before the piston starts to travel up again for the compression stroke.
Old Apr 26, 2014 | 04:35 PM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
You cannot measure 1 and 6 at the same time. One is on the compression stroke and the other is just finishing the exhaust stroke.
http://ls1tech.com/forums/generation...od-length.html
Old Apr 26, 2014 | 05:02 PM
93civEJ1's Avatar
93civEJ1
yeah i got it sorted out...just went by this instead:
Quote:
Originally Posted by Joseph
LSX Firing Order 1, 8, 7, 2, 6, 5, 4, 3
TDC Cyl. #1) Camshaft dot at 12:00 / Crankshaft dot at 12:00
TDC Cyl. #8) Camshaft dot at 1:30 / Crankshaft dot at 3:00
TDC Cyl. #7) Camshaft dot at 3:00 / Crankshaft dot at 6:00
TDC Cyl. #2) Camshaft dot at 4:30 / Crankshaft dot at 9:00
TDC Cyl. #6) Camshaft dot at 6:00 / Crankshaft dot at 12:00
TDC Cyl. #5) Camshaft dot at 7:30 / Crankshaft dot at 3:00
TDC Cyl. #4) Camshaft dot at 9:00 / Crankshaft dot at 6:00
TDC Cyl. #3) Camshaft dot at 10:30 / Crankshaft dot at 9:00
Old Apr 26, 2014 | 06:59 PM
reactor2's Avatar
reactor2
That's won't work with the LS1. Taking the intake manifold off to see the lifters, that is. With the LS1 you can only see the lifters with the heads off. You can see the pushrods with the valve covers off though.
Old Apr 26, 2014 | 07:03 PM
reactor2's Avatar
reactor2
7.25
7.325
I'm actually testing my pushrod length right now too. You need to make sure you are TDC compression, otherwise you might not be on the base circle.
Old Apr 26, 2014 | 07:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you actually are on the base circle and you are getting variations in push-rod length, there could be a few things that can cause it.
1. the rocker pedestal can be worn.
2. The rocker trunnion is worn.
3, The lifter internals are worn
Ive seen all three cause issues.
Bill
Old Apr 26, 2014 | 07:49 PM
93civEJ1's Avatar
93civEJ1
thanks...i got it figured out. my issue was i wasnt measuring each individual cylinder at TDC compression...i was measuring some at exhaust stroke as well.
To can anyone help asap.
