First thing to check would the fuses. Then check the accordion tube going from the door into the body. Sometimes the connections get bad and corroded in them.
The Black electric bokses in the doors, and there is connection too the comfort boks
Sorry but I have no idea what you are saying. Please try and explain what you did. Part numbers would help also. Also you say you replaced something in the "doors", did you work in the drivers door also?
I would want to know:
Can you operate the passenger window or mirror from the drivers side switch?
Can you do it with the passenger side door switch?
Pull your DIC trouble codes and let us know what you see.
Exactly what fuses did you check? I want fuse numbers.
hey no I can not run windows down either the right or left door. I have checked all the fuses in pasagersiden.
got the car last Thursday, so do not know what and how to look SID codes?
1. Turn ON the ignition switch, with the engine OFF.
2. Press the RESET button to acknowledge any warning messages present.
3. Press the OPTIONS button on the Driver Information Center (DIC) and hold.
4. While holding the OPTIONS button press the FUEL button 4 times within a 5 second period Include the H or HC after each code
hi ok it say:
10-PMC 1 CODES
28-TCS NO CODES
40-BCM NO CODES
60-IPC NO CODES
80 RADIO NO CODES
99-HVAC 1 CODES
AO-LDCM NO COMM.
A1-RDCM NO COMM.
A6-SCM NO COMM.
99-HVAC U1160 HC
You have an issue with communication in the serial bus. The ones related to your issue are LDCM, RDCM, and SCM. They are door (Left and Right) and seat control circuits. It may be the cause of your issue or just be preventing us from getting more details on the problem.
Did you buy the car with these issues?
Still waiting on information about any parts you have changed.
Now I would like you to pull your codes using the following so you actually get the specific codes. Pay attention to Post #2 by 8VETTE7.
hi yes i got the car on Thursday and these errors, I was told that it was easy to make.
I had deleted the error was in the 10-PMC 1 CODES, but still have the last in the 99-HVAC 1 CODES and it's called U1160 HC, I separated the comfort box yesterday and it seems that there is something that is burned , also I got hold of the previous owner, and when he had it seemed everything too work in the car.
