P1416 AIR System bank 2-B
Old Jul 19, 2002 | 05:57 PM
johnny v's Avatar
johnny v
Default P1416 AIR System bank 2-B
Can someone please tell me whta this DIC error code deals with and probable causes for it?? Just got this the other day but it disappeared. :confused:
Old Jul 19, 2002 | 10:59 PM
Face's Avatar
Face
Default Re: P1416 AIR System bank 2-B (johnny v)
Perform a search you'll find this is common.
The air check valve on the passenger side behind the intake manifold needs to be replaced, or one or more header bolts backed thier way out.
Old Jul 22, 2002 | 10:23 PM
JimLB's Avatar
JimLB
Was wondering the same thing. Picked this code up on the way to the Keys after driving 8 hours in the rain. Cleared it and picked it up again driving home, no rain this time. Guess I will check it in the morning.
Old Jul 23, 2002 | 08:29 AM
THRAP 42's Avatar
THRAP 42
Same post from another C5'er earlier. The P1416 relates to -
An AIR pump is used on this vehicle in order to lower the tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative.
Time for service.
later,
Old Jul 23, 2002 | 02:43 PM
mmorse's Avatar
mmorse
Default Re: P1416 AIR System bank 2-B (THRAP 42)
I had both sensors replaced. Apparantly, moisture can get to them and they rust and won't work properly. You will continue to get the code until the sensor is replaced. Usually they replace both banks.
To P1416 AIR System bank 2-B
