C 5 Gas guage
Old Apr 29, 2014 | 03:57 PM
Honzerman's Avatar
Honzerman
1st Gear
Default C 5 Gas guage
I have a 99 C5 convertible and after driving 45 - 60 minutes a bing noise comes from the dash telling me to check instruments and the fuel guage sits at empty. This happens EVERY time and all I have to do is turn ignition off and restart then all is OK but in 45-60 mins it repeats...same thing every time.
Any ideas, I been to GM dealers and they have no idea.http://forums.corvetteforum.com/imag.../Cdnsmilie.gif
Old Apr 29, 2014 | 04:08 PM
3boystoys's Avatar
3boystoys
Do a search, been covered hundreds of time.
Old Apr 29, 2014 | 04:43 PM
Irony's Avatar
Irony
Yup...Sea Foam. It's like Windex in "My Big Fat Greek Wedding"
Old Apr 29, 2014 | 04:54 PM
Chicago1's Avatar
Chicago1
most guys use techron or seafoam. I rather take the 45min 1hr and just replace the sensor in the tank and never have to worry about me wasting money every month for a band aid fix but that's just me. fix it and be done .and yes it has been literally beaten to death, Search engine is pretty good I highly recomend it. Good luck
Old Apr 30, 2014 | 12:03 PM
Mr. Jones's Avatar
Mr. Jones
and never return to that dealer
Old Apr 30, 2014 | 03:49 PM
SG Lou's Avatar
SG Lou
Old Apr 30, 2014 | 03:59 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by SG Lou
The EASYEST resolve is to run several concurrent tanks fills with the addition of a bottle of Chevron Techron Fuel System Cleaner OR Seafoam
The fuel Level Sensors (you have TWO) get contaminated with SULPHER DEPOSITS.
If you read your DTCs,,, you will be able to figure out what sensor or SENSORS are giving you issues.
If you do the concurrent treatments of fuel system cleaner and it still errors out, replacement sensors are in your future.
Read and post the DTCs
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
To C 5 Gas guage
