How to FIX these codes???
Old Apr 30, 2014 | 05:11 PM
dbs1vette's Avatar
dbs1vette
Default How to FIX these codes???
B0361H/B0441H. Both refer to hvac with one being a short to ground and the other an actuator out of range. Ideas???
P0103 HC refer to the PCM and the maf sensor having issues (I'm using a hall tech cai on this 416 and it has a LS7 style maf I believe)
C1296H. Mst cylinder pressure sensor circuit. This one is my biggest concern at the moment, with a road race coming up I'm not sure the negative consequences of this. Ideas? Thanks!!!
Old May 1, 2014 | 06:02 PM
dbs1vette's Avatar
dbs1vette
No one knows the answer to this admist all the corvette gurus here???
Or is there just no love to be found for my measly Z16????
Old May 2, 2014 | 07:17 PM
Idaho Hot Rod's Avatar
Idaho Hot Rod
Your hvac code is probably a cracked plastic gear in your actuator. Just replaced mine and it fixed it. There is a lot of info on this if you do a search. Guys have posted step by step instructions. Very helpful
Old May 3, 2014 | 08:23 AM
dadaroo's Avatar
dadaroo
Trying to address 3 completely separate issues in one Thread is crazy. Too difficult to follow who said what on what issue.
I assume you do not have a FSM?
Also you want help but we have no idea what year car you have. In particular this applies to your brake issue.
Old May 3, 2014 | 10:28 PM
Bill Dearborn's Avatar
Bill Dearborn
For the HVAC codes all you may have to do is recalibrate your HVAC actuators. Pull the fuse for the HVAC for at least 60 seconds. Then plug it back in and see if the actuators calibrate. Could save you the cost of buying new parts.
Bill
Old May 4, 2014 | 07:08 AM
dadaroo's Avatar
dadaroo
Bill
There are 2 fuses titled the same, HVAC Controls.
To How to FIX these codes???
