Idle air control motor
Old May 2, 2014 | 06:54 PM
19VETTE98's Avatar
19VETTE98
Cruising
Default Idle air control motor
Anyone know what tool it takes to remove the IACM ? it looks like a Torx, but I cannot get one to grab enough without slipping out. Any suggestions. My idle is fluxuating pretty bad. Some times it wants to die while in gear, which is causing a lean code to show up & in turn making the check engine light go on. I thought maybe if I removed the idle control motor & cleaned it, that might solve the problem. ,??
Old May 2, 2014 | 07:34 PM
RedZMonte's Avatar
RedZMonte
I thought the C5 had the IAC built in to the throttle body via the tune in the Ecu to control the throttle plate in the electronic throttle body... dont believe it has a IAC like most cars..
My guess is it is elsewhere, what are the situations it dies? might be a crank position sensor...
Do you have any mods, if so what are the? has the car ever been tuned?
Old May 2, 2014 | 07:39 PM
RonSSNova's Avatar
RonSSNova
No iac on the C5 or any drive by wire car for that matter.
What the OP is seeing is the throttle position sensor.
They are a special torx with a pin in the middle.
Old May 2, 2014 | 07:55 PM
19VETTE98's Avatar
19VETTE98
Cruising
Do not have any mods. The idle is erratic, some times it is fine , while other times it wants to go very low or die. It is worse under load, ie... with the A/C running. I have owned the car for a year now, so don't know of the tuning history. I have not had it tuned. Thanks for your help, any suggestions are greatly appreciated.
Old May 2, 2014 | 08:05 PM
pbfrench's Avatar
pbfrench
Mine was doing the same, I cleaned the throttle body and as far as the brush would go into the intake. Took care of the issue.
Old May 2, 2014 | 08:17 PM
19VETTE98's Avatar
19VETTE98
Cruising
Could the TPS cause the erratic idle, or does it just sence the position and relay the info to the computer?
Old May 4, 2014 | 06:56 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Try cleaning the MAF and TB.
Old May 4, 2014 | 08:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The problem most likely lyes else where.
Check ALL the VACUUM LINES from end to end.
Clean your MAF with MAF cleaner and the Throttle blade.
Make sure that the air ducting between the MAF and the TB are properly sealed air tight and don't let in un-metered air.
The PCM controls the position of the Throttle Blade to get the proper idle.
BC
Old May 5, 2014 | 09:35 AM
3boystoys's Avatar
3boystoys
They are security bits (like they use in bathrooms to keep the thugs from taking the bathroom apart). I've also seen these fasteners in Microwave ovens to keep your average Joe out of the high voltage microwave bits. I have an entire kit with all the security bits but as the others have stated, a good cleaning of things and checking for vacuum leaks should be the 1st thing you do.
Old May 6, 2014 | 04:47 AM
19VETTE98's Avatar
19VETTE98
Cruising
BC
Thank you for your help, I will clean both as you suggest. TM.
Old May 6, 2014 | 04:51 AM
19VETTE98's Avatar
19VETTE98
Cruising
Thanks to everyone for all the help, hopefully a good cleaning & thorough inspection will do the trick, Thanks again,..... Terry
Old May 6, 2014 | 03:52 PM
19VETTE98's Avatar
19VETTE98
Cruising
UPDATE......
I cleaned the Throttle body & MAF with the correct CRC cleaners. I also installed a K&N air filter & inspected all vacum & electrical connections.
Problem solved!!!!! It idle's smooth & seems to have a lot more power.
You guys on this forum ROCK! Thank You ! that's all I can say. Terry M.
To Idle air control motor
