C5 upgrade to C6 Paddle shift
Old May 3, 2014 | 05:01 PM
chuckeb84's Avatar
chuckeb84
Default C5 upgrade to C6 Paddle shift
Is this even possible
Does the C6 trans fit in a C5
I was just thinking of adding a clutchless shifter option
Old May 3, 2014 | 06:25 PM
65GGvert's Avatar
65GGvert
The A4 in the C5 is already a clutchless shifter option. The C6 paddle option is on a 6 speed automatic transmission. Neither the paddle shifter nor the A4 use a clutch, so I'm not sure what you're going from and to.
Old May 3, 2014 | 07:02 PM
chuckeb84's Avatar
chuckeb84
[QUOTE=8VETTE7;1586813441]Seems like lots of nubies ask this question and the answer is still the same. with enough money you can accomplish just about anything but in this case benefits and cost are wide apart.
Search would bring up LOTS of threads about this if you learn how to use it.
Here is a start for you:
http://forums.corvetteforum.com/c5-t...nsmission.html[/QUO
You can change gears at will on a paddle not an auto
Old May 3, 2014 | 07:06 PM
chuckeb84's Avatar
chuckeb84
You can change gears at will on a paddle not an auto:toe tap:
https://www.tciauto.com/tc/shifters/paddlehtml
Old May 3, 2014 | 07:07 PM
chuckeb84's Avatar
chuckeb84
Or
http://www.mastershift.com
chuckeb84's Avatar
chuckeb84
Originally Posted by chuckeb84
I'm speed reader
Old May 3, 2014 | 07:47 PM
onlyavette's Avatar
onlyavette
I'm speed reader
Okay, we will call you"speed reader" from now on.
Old May 3, 2014 | 07:51 PM
chuckeb84's Avatar
chuckeb84
lol
To C5 upgrade to C6 Paddle shift
