How to remove shift knob?
Old May 3, 2014 | 10:36 PM
WannaC5Z's Avatar
WannaC5Z
Default How to remove shift ****?
So I bought a nice converted C6 **** for my C5 but it came with zero instructions. I recall reading you simply twist off the stock and twist on the new in two minutes. However when I attempt to remove the stock **** it seems likes it is twisting the shaft and doesn't want to come loose. Is there more to it? Am I missing something? I don't see a set screw on either the stock or new ****.
Old May 3, 2014 | 10:45 PM
chris308's Avatar
chris308
pop the shift pattern tab off, then fight the metal pin out then twist off.
Old May 3, 2014 | 11:06 PM
SavageLand's Avatar
SavageLand
It's very hard to get that pin out, I just did that a few weeks ago. You are fighting a little horse shoe shaped pin at the base of the factory shift ****; It's really deep in there. I used an "awl" and a set of needle nose pliers and just inched that sucker out of there. It requires a little picking and digging but it will eventually pop out.
Here is a pic of where the pin resides highlighted in yellow. I hope this helps. I found though afterwards getting a new shift **** to work was actually pretty easy (and looked way better). Best of luck!
Old May 3, 2014 | 11:10 PM
StingrayRebel's Avatar
StingrayRebel
I think the op has a 6spd so that pic won't help him... you need to pop off the shift pattern cap on top of the shift **** and use something to pry or pull out the metal pin and then the **** will come right off
Old May 4, 2014 | 09:40 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Instructions here:
http://www.conceptualpolymer.com/corvette_install.htm
Old May 4, 2014 | 10:26 AM
WannaC5Z's Avatar
WannaC5Z
Yes a Z06 so a 6-speed. Thanks guys!
Old May 9, 2014 | 04:43 PM
WannaC5Z's Avatar
WannaC5Z
Originally Posted by alxltd1
The links not working any longer for some reason.
Old May 9, 2014 | 04:44 PM
Endeka's Avatar
Endeka
Pop off shift pattern tab.
Locate demon key
pray to Jesus
if prayer is answered, key will be extracted with minimal effort
You're done.
Old May 9, 2014 | 04:54 PM
alxltd1's Avatar
alxltd1
OK. try this one:
http://www.vetteessentials.com/instr...t_install.html
Old May 12, 2014 | 08:59 PM
WannaC5Z's Avatar
WannaC5Z
I used a narrow flat head screwdriver to pry it out fairly easily.
To How to remove shift knob?
