Brake Install Problem
Old May 4, 2014 | 12:33 AM
jlaw1313@comcast.net's Avatar
Default Brake Install Problem
This pic is after bedding in HPS brake pads on new rotors. I purchased the brake calipers from a forum member. The 3/4 inch ring on the rotor around the hat does not look right, I do not think the pad is coming in contact with the rotor. Any opinions?
Old May 4, 2014 | 02:28 AM
Smokin Joe's Avatar
Smokin Joe
Are the pads new?
Old May 4, 2014 | 07:36 AM
strand rider's Avatar
strand rider
I would think you could check for pad contact in a number of easy ways. Perhaps a chalk line on the rotor as a tattle tale, a paper inserted etc., if the width of the pad cannot now be measured.
I have so little to add, I can almost hear all the eye rolling out there, and that makes no sound at all, that's how weak is my obvious suggestion . Is it still called a blabber mouth if you type it out?
Old May 4, 2014 | 08:09 AM
Originally Posted by Smokin Joe
Are the pads new?
Yes, the pads are new. I am going to pull apart and double check rotor size and pad size.
I do not know how to check the calipers if they are bent.
Old May 4, 2014 | 08:37 AM
dadaroo's Avatar
dadaroo
You know the pads are contacting in the outer area. Put a straight edge on the pads to make sure they have a consistent thickness.
Remove the wheels are turn the steering wheel so you can get a clear look at everything.
What does the other side look like?
Old May 4, 2014 | 10:09 AM
Smokin Joe's Avatar
Smokin Joe
Debris on the pad is my guess. Is it scoring or a mark? I doubt your calipers are bent. Does make noise while driving? While spinning the wheel by hand? Did you rice the rotor with brake cleaner? Did you touch the pad surface with greasy fingers?
Old May 4, 2014 | 05:45 PM
I cleaned all the rotors with brake clean and then a quick wipe two times with acetone.
I replaced all of the brakes and rotors. This problem seems to be isolated to the front left brake.
I do not feel any vibration or hear any unusual noise.
Old May 4, 2014 | 05:48 PM
The the inner rotor surface looks okay.
Old May 4, 2014 | 05:50 PM
Having a heck of a time attaching pics tonight.
Old May 4, 2014 | 05:58 PM
The gray area at the bottom of the pad is not contacting the rotor. When using a staight edge there is a very slight gap at this area. The lighter portion of the pad is what is making contact with the rotor.
I also found the lower caliper slide pin bolt not completely seated against the caliper bracket. The caliper pin bolts were new factory, it looked like the bolt received a double coat of thread lock making it hard to turn as it was torqued 23 ft lbs. I cleaned and removed the factory applied thread lock and reassembled using Blue Loctite.
Old May 4, 2014 | 07:44 PM
Smokin Joe's Avatar
Smokin Joe
Originally Posted by jlaw1313@comcast.net
http://forums.corvetteforum.com/memb...ad-171599.html
The gray area at the bottom of the pad is not contacting the rotor. When using a crappy staight edge there is a very slight gap.
I also found the lower caliper bolt not completely seated against the caliper bracket. The caliper bolts were new factory, it looked like the bolt received a double coat of thread lock making it hard to turn as it was torqued 23 ft lbs. I cleaned and removed the thread lock and reassembled using blue Loctite.
It's raining now. I'll take it for a test drive tomorrow.
Someone correct me if I'm wrong... That's a red loctite item, based on temp and stress I think. Loctite has a decision tree on their website to determine which one. Make sure those bolts are in and torqued. No bueno if one backs out on you.
I think the pads will wear in. I wouldn't be concerned if it's not scoring the metal surface of the rotor.
Old May 4, 2014 | 09:04 PM
To make sure, we are talking about the caliper pin bolts not the caliper bracket bolts. I did edit my last post. I went with Blue Locktite because that is what color the factory applied thread loc is. That was a shallow assumption on my part. I will follow that up, thanks.
Concerning the bow in the Hawk HPS brake pad: I 'll see if I can contact someone at Hawk Performance.
Old May 4, 2014 | 10:12 PM
Mr. Evil-Twin says "Blue" for the caliper pin bolts.
There are a few different opinions on this subject:
http://forums.corvetteforum.com/c5-t...ing-bolts.html
Old May 4, 2014 | 10:38 PM
Meta's Avatar
Meta
Caliper spread, possibly?
Old May 4, 2014 | 10:51 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
I wouldn't worry too much. In a thousand miles it will be worn into full contact.
Old May 5, 2014 | 01:41 AM
Smokin Joe's Avatar
Smokin Joe
Ok blue. I couldn't remember what Loctite's website said.
To Brake Install Problem
