Verifying Trans Fluid Temp sensor function
I asked RPM to install the TFT sensor in my MN12. How do I verify the sensor, and the wires I added to my wiring harness for this function are working correctly? I am getting no codes. I have tracked the car once already.
If I temporarily short the TFT High Signal (to GND, with key on) will it trigger the DIC warning "TRANS TEMP HIGH"?
I ask because I am sensetive to the trans temp issue and I don't want to burn up this new one.
Thanks in advance.
This is per the Temp vs. Resistance table in the Engine Controls section.
So... I should be able to measure ~ 2.5K - 3K ohms at ambient temp (per the table) at the pins going into the PCM for the TFT sensor. That will verify the sensor and wiring functionality.
