Differential Question
Old May 9, 2014 | 02:36 PM
donnie brooks's Avatar
donnie brooks
Default Differential Question
After driving my car about 200 miles I noticed a tiny bit of.. what looks like differential fluid.. on the concrete on each side of differential.
I jacked up the rear and got a good look at each side where the shafts exits the differential..there is no sign of any wetness at all on either side..so I was wondering if maybe the overflow on top was causing this..I did recently change the fluid and may have put too much in it,also the drip was on the very bottom of the bolts that bolts the sides of the differential,I did check to make sure the bolts are tight..so any help you can provide will be greatly appreciated.
