Crazy electrical demon..
Old May 9, 2014 | 09:33 PM
1dwn5up's Avatar
1dwn5up
Default Crazy electrical demon..
I just got my headers installed last week and all was good until yesterday during a hard 2-3 shift my gauges went crazy for a second, my ABS light came on and the car kind of hesitated. Now I'm getting codes and reduced power, shocks inoperative, service active handling.. the codes are
P1652
U1016
1040
1096
1064
B1001
B0516
B2723
Also now it randomly does all this whenever it seems to feel the need to irritate me...
Any ideas on this problem?
Old May 10, 2014 | 04:37 AM
baxsom's Avatar
baxsom
My guess is there are wires near the headers with melted insulation and the hard shift caused them to ground out to the header.
Old May 10, 2014 | 08:17 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When multiple systems are affected all at the same time,, most of the time its related to a serial data buss corruption issue OR a BCM issue.
One primary culprit of serial data buss problems are the LDCM, RDCM and or the Seat Module.
The door modules cause issues because the power connector for the module (located in the hole in the door opening A pillar where the accordion tube attachés) has damaged female pins. The pins spread and make POOR contact with the male pin. The poor connection causes the module to turn ON and OFF rapidly and the digital data on the modules serial data wire spazzes out.
The drivers seat power connector can sometimes get damaged because it comes out of its holder. Ive also seen it get wet due to leaks. Be it damaged or wet, the same bad serial data causes issues on the serial data buss.
Here is a door control module power connector with a damaged female pin that caused the same corruption:
Bend the small tong back up with a pick. The proper way to test a female pin to make sure it has the proper tension on the male pin is to do a PIN PULL TEST using a spare male pin. When you insert and extract the male pin, it should have tension going in and pulling it out.
IF,, you have a solid serial data buss fault, there is an easy way to eliminate the LDCM, RDCM and Seat Module from the equation with one easy procedure.
To the LEFT of the Body Control Module (BCM) are two thin connectors. They are the STAR BUSS connectors. All of the serial data wires from all modules and the OBDII port join here.
The connector with FOUR wires is the connector where the LDCM, RDCM and SCM join. If you pop the top of the connector, you isolate those three modules from the rest of the modules. The top of the connector is a shorting tie that connects all the wires together.
Your best path would be to examine BOTH door control harness power connectors and work any female pins that are spread apart. For the most part, they are the issue.
I would also make sure that the BCM and or the area around it isn't wet or damp. Check under the carpets and under the seat for moisture.
The BCM does NOT like to get wet or damp!
Bill
Old May 10, 2014 | 09:23 PM
1dwn5up's Avatar
1dwn5up
I only got as far as the star connector today between rain showers.. carpet seemed damp but I think it was just the weather today. Just to be safe I pulled out the carpet for good measure and it was dry underneath and the BCM has no signs of water entry. So I pulled the shorting bar for the door control modules. They now show no comm on the DIC when I pull the codes as I assume they should but I am still getting the P1652 H C code and when I cycled the key on and off a couple of times the normal corvette by Chevrolet came up on the DIC and it went right to traction/ active handling on. I'm just hoping this is not a BCM problem because the car is a 99.. Any possibility it could be the ignition switch?
Old May 10, 2014 | 10:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OH MY!! You have Real Time Dampening F-45 Suspension.
Program that CRAP out of the BCM and install some real Shocks, Sway Bars and Springs.
Document ID# 317263
1999 Chevrolet/Geo Corvette
DTC P1652 Powertrain Induced Chassis Pitch Output Circuit
Circuit Description
The PCM controls the Powertrain Induced Chassis Pitch by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the controlled component. The driver has a fault line which is monitored by the PCM. When the PCM commands a component ON, the voltage of the control circuit should be low (near 0 volts). When the PCM commands the control circuit to a component OFF, the voltage potential should be high (near battery voltage). If the fault detection circuit senses a voltage other than what the system expects, the fault line status changes causing the DTC to set.
The PCM receives an ignition voltage feed from the Electronic Suspension Control module on the Powertrain Induced Chassis Pitch circuit. The PCM grounds this circuit when the vehicle accelerates rapidly or brakes hard. When the chassis pitch input circuit goes low (about 0 volts), the ESC module commands all four shock absorber solenoids to a firm position. The PCM calculates the chassis pitch information based on the engine torque and the vehicle braking force.
Conditions for Running the DTC
Engine speed greater than 400 RPM.
The system voltage is greater than 6 volts but less than 18 volts.
Conditions for Setting the DTC
The PCM detects that the commanded state of the driver and the actual state of the control circuit do not match.
The condition must exist for a minimum of 5.0 seconds.
Action Taken When the DTC Sets
The powertrain control module (PCM) stores the DTC information into memory when the diagnostic runs and fails.
The malfunction indicator lamp (MIL) will not illuminate.
The PCM records the operating conditions at the time the diagnostic fails. The PCM stores this information in the Failure Records.
Conditions for Clearing the DTC
A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
A history DTC will clear after 40 consecutive warm-up cycles, if no failures are reported by this or any other non-emission related diagnostic.
Use a scan tool in order to clear the DTC.
Diagnostic Aids
Important
Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules.
For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
Ensure that the vehicle is equipped with Electronic Suspension Control (ESC). This DTC sets when the BCM is programmed if the RPO for the Electronic Suspension Control (ESC) is selected as active and the vehicle is not equipped with Electronic Suspension Control (ESC).
Using the Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can help determine how many miles since the DTC set. The Fail Counter and Pass Counter can also help determine how many ignition cycles the diagnostic reported a pass and/or a fail. Operate vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature etc.) that you observed. This will isolate when the DTC failed.
The following may cause an intermittent:
Poor connections; Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
Corrosion
Mis-routed harness
Rubbed through wire insulation
Broken wire inside the insulation
For an intermittent condition, refer to Symptoms .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step determines if the Powertrain Induced Chassis Pitch control circuit is shorted to ground.
This step determines if the Powertrain Induced Chassis Pitch control circuit is open or, the PCM is unable to control the Powertrain Induced Chassis Pitch control circuit.
Step
Action
Value(s)
Yes
No
1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
Turn OFF the ignition.
Install a scan tool.
Disconnect the Electronic Suspension Control (ESC) Module. Refer to Electronic Suspension Control Module Replacement in Real-Time Damping (RTD).
Turn ON the ignition leaving the engine OFF.
Probe the Powertrain Induced Chassis Pitch Control circuit at the ESC electrical connector using the test lamp J 34142-B connected to B+.
Does the test lamp illuminate?
Go to Step 4
Go to Step 3
3
Command the Chassis Pitch Signal ON using the scan tool.
Go to RTD Diagnostic System Check in Real-Time Damping (RTD)
Go to Step 5
4
Test the Chassis Pitch Control circuit for a short to ground. Refer to Testing for Continuity in Wiring Systems.
If you find a grounded circuit , repair the circuit as necessary. Refer to Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 8
Go to Step 7
5
Test the Chassis Pitch Control circuit for an open. Refer to Testing for Continuity in Wiring Systems.
If you find an open circuit, repair the circuit as necessary. Refer to Wiring Repairs in Wiring Systems.
Go to Step 8
Go to Step 6
6
Inspect for a poor connection at the PCM. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
If you find a poor connection, repair the terminal as necessary. Refer to Wiring Repairs in Wiring Systems.
Go to Step 8
Go to Step 7
7
Important:
Program the replacement PCM. Refer to PCM/TAC Module Replacement .
Replace the PCM.
Is the action complete?
Go to Step 8
8
Select the Diagnostic Trouble Code (DTC) option and the Clear DTC Information option using the scan tool.
Idle the engine at the normal operating temperature.
Select the Diagnostic Trouble Code (DTC) option and the Specific DTC option, then enter the DTC number using the scan tool.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test ran and passed?
Go to Step 9
Go to Step 2
9
Select the Capture Info option and the Review Info option using the scan tool.
Does the scan tool display any DTCs that you have not diagnosed?
Go to applicable DTC table
System OK
Document ID# 317263
Old May 10, 2014 | 11:01 PM
1dwn5up's Avatar
1dwn5up
That is actually my next step.. Unfortunately where I live there is a lack of reliable places that could reprogram my BCM. Even less options on folks that I would let work on the car. Any helpful hints on where I should start looking for problems with this? I don't have access to a tech 2 the best I can manage would be a snap-on scan tool. If it helps I already have the seat and the carpet out of the passenger side and if I remember correctly there is a sensor there that has something to do with the F45 garbage
Old May 10, 2014 | 11:05 PM
1dwn5up's Avatar
1dwn5up
Am I even safe to drive the car right now with it acting this way? I don't really want to end up with a tow bill or things more screwed up than they already are
Old May 10, 2014 | 11:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The senspr has more to do with the EBTCM. Its the YAW Sensor.
Check the PINK/White stripe on connector C2 pin C5 on the rear time dampening module in the rear compartment left compartment.
It goes to PCM Connector C1 Pin 38
Thats the signal wire that you are having issues with. The signal should be Battery Voltage or ZERO volts.
Check both connectors
Old May 10, 2014 | 11:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The F45 shocks default to a fail safe setting and YES, you can drive the car. It might say your restricted to speeds less than 80 MPH.
Bill
Old May 11, 2014 | 08:21 PM
1dwn5up's Avatar
1dwn5up
Well things went a little more crazy today.. When I cycled the key on the gauges did nothing for about 3-4 seconds, the check engine light was lit up but only about half brightness then all of a sudden the gauges did their normal sweep. then I got the reduced engine power message and all the others again.. this thing is just about to drive me insane.
Old May 11, 2014 | 09:20 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,, that additional info would have you checking to see if the IGNITION SWITCH needs work or replacement:
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Bill
Old May 11, 2014 | 09:46 PM
1dwn5up's Avatar
1dwn5up
Here's a pic of it.. also I noticed my fuel level was showing empty and I know for a fact I have at least half a tank
[IMG][/IMG]
Old May 11, 2014 | 11:44 PM
1dwn5up's Avatar
1dwn5up
Is it really possible my switch could be causing all these headaches?
Old May 12, 2014 | 01:45 AM
1dwn5up's Avatar
1dwn5up
I guess I'll be pulling that out in the morning then, hopefully this fixes the problem
Old May 12, 2014 | 05:06 PM
1dwn5up's Avatar
1dwn5up
Well I pulled apart the ignition switch today but didn't have a multimeter handy but it looked a bit scorched so I cleaned it all and rebent the contacts and so far so good. No codes other than my usual SWPS and active handling warming up. Hopefully things are fixed for good! Now to find a decent place to have the F45 garbage turned off... Thanks for all the help
Old May 13, 2014 | 09:28 AM
Biotex's Avatar
Biotex
Would you mind telling me the basics of what you have to pull apart to be able to access the switch? Like for instance you have to remove the console? radio bezel? etc...
I'm going to be cleaning mine up also, as I'm chasing a few codes myself. Any tips would be great.
Old May 14, 2014 | 01:14 AM
1dwn5up's Avatar
1dwn5up
Had to remove the console, radio bezel, and the lower dash panel. In all I think it took me about 2 hours total working really slow
To Crazy electrical demon..
Old May 30, 2014 | 09:27 PM
1dwn5up's Avatar
1dwn5up
OK so I rebuilt the ignition and all the problems went away for about a weeks worth of driving and today it all came back except it's worse.. car shut down and didn't want to start back up.. got the pull key wait 10 sec message and all the same codes again.. idle was all over the place and wanted to keep stalling... should I just replace the switch or start tracing wires and looking for a short.
Old May 30, 2014 | 09:49 PM
1dwn5up's Avatar
1dwn5up
I don't have much faith in the dash gauges but it was showing 12.0 or 12.1 before I started the car..I did just put a brand new optima red top in it about a month ago because the old battery was weak. I'll definitely check the battery first thing tomorrow and go from there.. I forgot to mention this all happened the day after about a 160 mile trip but I had 0 problems up until then.
Old May 30, 2014 | 09:58 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The PULL KEY WAIT 10 SEC message deals with the resistor chip in the key and or the chip reader in the Sensor attached to the key cylinder.
If it cant read the proper resistance,,,, it will NOT start.
Several things can cause that issue. dirty key pellet, Bad key pellet,, bad sensor, poor connection in the VATS circuit.
BC,
