Diagnosing Knock LS1 (Video inside)
Old May 12, 2014 | 10:35 AM
PEETYZ's Avatar
PEETYZ
Default Diagnosing Knock LS1 (Video inside)
Well I randomly got a tick/knocking sound in my LS1 this weekend. This is actually on my GTO not the vette but same engine.
PRC 5.3 heads, comp cam, dual springs, Fast intake, etc. Motor has stock lifters and rockers with 126k and they have done the job thus far but I feel one may be the culprit.
Symptoms:
-Random knock low rpms seems to smooth out in upper rpms ( hope it rules out a bearing) Appears to be on passenger side in valvetrain area
-Runs great does not appear to be missing, not smoking, acting funny in any aspect.
-Header bolts are tight.
-Pulled valve cover and the springs and rockers appeared to be good.
-Changed oil and it was particle free no metal flakes, shavings, etc.
Clip here:
Thanks in advance!
Old May 12, 2014 | 11:50 AM
Mr. Jones's Avatar
Mr. Jones
how about a crack in a single header pipe?
maybe add a little seafoam to the intake and look for smoke near the motor/header.
Old May 12, 2014 | 02:51 PM
PEETYZ's Avatar
PEETYZ
I will give that a shot. Thanks!
Anyone else?
Old May 12, 2014 | 04:18 PM
78GEN3's Avatar
78GEN3
Is this an auto? Check out your TQ converter bolts make sure they are tight.
Old May 12, 2014 | 04:36 PM
PEETYZ's Avatar
PEETYZ
6 speed car. The noise appears to be loudest on passenger side of motor on the middle 2 cylinders almost like its coming from under the intake manifold. Maybe a slow lifter?
Old May 15, 2014 | 09:24 PM
old stingray's Avatar
old stingray
Could it be a rocker arm with bad/missing bearings?
Old Jul 15, 2014 | 01:27 PM
69autoXr's Avatar
69autoXr
Any resolution?
To Diagnosing Knock LS1 (Video inside)
