4L60E Swap
Old May 12, 2014 | 08:46 PM
BrianAgar's Avatar
BrianAgar
Default 4L60E Swap
I need to upgrade my auto tranny. I was told the best one out there that can handle 660 HP is the 4L80E; is this correct. Also, would a Tremec trans out of a 2005 c6 corvette along with the differential fit on my C5? If so, which would you all recommend?
Thank you in advance for any guidance,
Brian
Old May 12, 2014 | 10:36 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
If you want to stay with the auto, contact rpm. They are a supporting vender and from what I have read here, build some pretty stout and reliable 4l60E transmissions. Swapping to a 4l80E is an expensive mod.
Old May 12, 2014 | 11:01 PM
BrianAgar's Avatar
BrianAgar
Default thanks
Thanks for the idea and tip, and I'll look into it.
Old May 13, 2014 | 06:07 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
4L80 will not fit the C5 without modification to the Trans tunnel. And it's expensive.
As mentioned above, Rodney at RPM can hook you up with a badass transmission.
Swapping to a T56 is also an expensive proposition.
Old May 13, 2014 | 10:36 AM
thumpinc5's Avatar
thumpinc5
Don't discount the ability of the 4L60E if it's built right. Unfortunately, there's a shortage of competent builders in the country. We have them running 9.7s in 3600 # cars and 9.8s in 4200# cars. They can be built to handle 1000 + horsepower.
Frank
Old May 13, 2014 | 11:07 AM
BrianAgar's Avatar
BrianAgar
thanks for the info.
Old May 13, 2014 | 11:08 AM
BrianAgar's Avatar
BrianAgar
Frank
thanks Frank. I'll look into it.
Old May 13, 2014 | 06:25 PM
torchvette10's Avatar
torchvette10
Definitely consider contacting rpm transmissions! They build some strong transmissions and they really stand behing their products
www.rpmtransmissions.com
Old May 14, 2014 | 01:35 PM
sean.b's Avatar
sean.b
i'd go back to RPM for another 4l60 if that's what i was doing. being as i do my work myself and enjoy a challenge, i'd do a 4l80 before doing another 4l60. just to be unique, if not applicable
As far as the t56 being an expensive swap - I have to disagree. if you do it yourself, its really not bad at all, if you factor in selling or trading your auto stuff. even if you find a shop, you can find it done for ~$1500 all day. i did get quotes as high as $3k, but shop around (and shop with people with reputations..)
Old May 14, 2014 | 01:38 PM
BrianAgar's Avatar
BrianAgar
Default Thanks
Thanks for the info.
BrianAgar's Avatar
BrianAgar
Old May 17, 2014 | 02:03 PM
BrianAgar's Avatar
BrianAgar
Thank you Sean. If I pick up a solid T56, I should be able to rebuild it for "about" the same price. However, I think I'm just going to rebuild my tranny. I did some research and found the 4l60 it's just am upgraded 700R4, which I had and ran with a 4.10 gears and almost 1000 hp. That would worked for me, so I'm sticking with the 4l60.
Old May 17, 2014 | 02:06 PM
sean.b's Avatar
sean.b
Originally Posted by BrianAgar
Thank you Sean. If I pick up a solid T56, I should be able to get it and rebuild it for "about" the same price. However, I think I'm just going to rebuild my tranny. I did some research and found the 4l60 it's just am upgraded 700R4, which I had and ran with a 4.10 gears and almost 1000 hp. That would worked for me, so I'm sticking with the 4l60.
nothin wrong with that. you'll find 4l60e's and race applications a very polarized issue. people either firmly believe they can work, or think they're all made of butter. but there's enough people with built up 4l60's doing work with 1000+ hp that there's no reason to believe it cant work. that 1-2 drop sucks, but if you throw gearing at it, you're fine.
Old May 17, 2014 | 05:45 PM
RonSSNova's Avatar
RonSSNova
Actually Sean, if you have a good converter, the 1-2 isn't so much of an issue.
My data logs show nearly identical drops from 1-2 and 2-3.
And if.....if you have 1000hp, you won't care anyway. :-)
Ron
Old May 19, 2014 | 09:01 PM
HardcoreABN's Avatar
HardcoreABN
just a FYI, a 4L80 swap is about $10,000....
Unless you are running 8s a 4L60/65 will be sufficient and durable.
The 4L60 is an upgraded 700R4. The 4L60/65e and 4L60 are different transmissions.
Old May 19, 2014 | 09:14 PM
sean.b's Avatar
sean.b
Whoa. Ok. I don't need to be that damn unique.
Old May 19, 2014 | 09:17 PM
sean.b's Avatar
sean.b
Ron
Didn't even consider that but ya, makes more sense than rear end letting the convertor keep rpm up. And yea with 1000hp you can get away with a powerglide
Old May 23, 2014 | 02:51 AM
ajrothm's Avatar
ajrothm
A 4l80 swap is way more then $10k... The parts alone are over $15k.. Not to mention extensive labor/hacking to make it work..
For 800-900rwhp, the RPM level 7 4l60 will hold you for a while.... Not forever....but for a while.. 3-4 clutches are the first to go.
I've ran a hand full of 9.22-9.35 passes at 3600lbs with the level 7 and it never misses a beat.
To 4L60E Swap
