Water pump replacement
Old May 14, 2014 | 11:56 AM
jcs44's Avatar
jcs44
Default Water pump replacement
Took my 03 Z06 to dealer for some routine stuff and was told that water pump is leaking and needs to be replaced. Dealer says $800 and is supposedly trustworthy on Vettes. What do you all think?
jcs44
03 C5Z
Old May 14, 2014 | 12:05 PM
dblerman's Avatar
dblerman
It shouldn't be more than $350 parts and labor...Unless they charge $300/hr...
You can buy a new pump for less than $150....It's super easy to change out yourself...
Old May 14, 2014 | 12:07 PM
adamgl's Avatar
adamgl
Does that come with a lube job before they screw you? lol
Old May 14, 2014 | 12:22 PM
jcs44's Avatar
jcs44
I checked with another dealer: Pump with gaskets, new design inlet and belts comes to $460 plus $190 for labor = $650, a bit cheaper
Old May 14, 2014 | 12:30 PM
adamgl's Avatar
adamgl
Waterpump is $105 on rock auto with gasket.
Old May 14, 2014 | 01:17 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Ya, one at a autozone is like 130$. Then add 30$ for coolant. Do it yourself. Easy cheesy
Old May 14, 2014 | 01:51 PM
runner140*'s Avatar
runner140*
As said above, it takes simple tools and is a straight forward job....belts, the water pump, gaskets, and DexCool and distilled water.
Do it yourself...save money and have a feeling of accomplishment.
Old May 14, 2014 | 05:35 PM
The Void's Avatar
The Void
I replaced mine with the updated C6 version of the pump. You could do it yourself and save a little money. Without knowing your skills/tools/comfort level it might be worth having someone do it for you.
It is a straight forward process but you are going to have to drain/dispose of the antifreeze(and spill a little in the process). Then you are going to need to make sure you get all of the air out of the system. It will take you a few hours as a novice. And any time I touch the car I bleed.
If you like to be hands on it is rewarding to do stuff on your own, but there is something to be said for saving the time and effort to get it done.
Search Amazon for:
ACDelco 89018052 Water Pump Assembly
It is supposed to be slightly lighter with the smaller pulley on the front. What I used.
Old May 14, 2014 | 06:22 PM
guido7834's Avatar
guido7834
Did you confirm that the pump is actually leaking? If they want to gouge you for that much, who's to believe you actually need one?
Old May 14, 2014 | 07:13 PM
Chicago1's Avatar
Chicago1
Originally Posted by The Void
You could do it yourself and save a little money. .
I think saving 670 bucks is a lot more then saving a little money...
Op the job is pretty simple DIY and save that cash and put it in some upgrades!!!
Old May 15, 2014 | 01:36 AM
striper's Avatar
striper
My first question would be why do you need a new pump? Show me. Then I'd do it myself, if you able to, and save a ton of money. That is truly a rip-off price.
Old May 15, 2014 | 11:32 AM
StingrayRebel's Avatar
StingrayRebel
for that much you could get an electric waterpump lol... I agree just do it yourself, gain the knowledge, and save your money... or use the money you aren't paying them for another mod, that's how I justify my spending sometimes
To Water pump replacement
