lower seat foam install
Old May 15, 2014 | 11:38 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
Default lower seat foam install
I bought the dj motorsports lower seat foam along with the seat repair kit by tfs. Not too hard to do. Took just over an hour.
Old May 15, 2014 | 11:43 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
Original seat foam was dated 7/22/99. The wires cut through all the way to the pleather
Old May 15, 2014 | 11:46 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
Some pics of the seat repair kit from the bottom. The blue foam pieces on each side.
Old May 15, 2014 | 11:48 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
You can see from the impression on the pleather how much the old foam sagged. About an inch.
Old May 15, 2014 | 02:25 PM
Mickeyrx70's Avatar
Mickeyrx70
When I replaced mine, I sat at least an inch higher, probably more. My drivers side foam was totally shot, especially the outside bolster. The seat is so much more comfortable now.
Old May 15, 2014 | 03:37 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Definitely at least an inch higher. Much firmer. Only annoyance right now is the sides are pushing into my thighs. It's getting better. I may remove the repair foam inserts.
Old May 15, 2014 | 09:03 PM
frsr06's Avatar
frsr06
Old May 16, 2014 | 12:43 AM
Smokin Joe's Avatar
Smokin Joe
Great job!
I just put my passenger side back together tonight after repairing the air bladders and adding a seat heater. The passenger sign was fine with minimal wear.
We'll have to see how the driver side is later this weekend.
Old May 16, 2014 | 12:49 AM
racebum's Avatar
racebum
the taller part drove me nuts. i eventually found a wrecked car with 14k miles to rob the foam from
unless you guys happen to be short that taller foam had my heat on the headliner and i'm only 5'11-6'
Old May 16, 2014 | 07:25 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
I'm 5'9" at first I had to tilt my head because I was sitting so much taller to look out window. Now I'm fine with it. I still have plenty of head room.
Old May 21, 2014 | 07:13 AM
NatB's Avatar
NatB
The lower seat foam looks like a great idea.
What is the "tfs seat repair kit" ?
Old May 21, 2014 | 08:16 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
https://www.corvetteforum.com/c5-par...-in-stock.html
Old May 21, 2014 | 11:18 AM
Pirateslife4me's Avatar
Pirateslife4me
Nice job man, I just replaced mine too and I thought it was just me when I noticed how much higher up I sat. Feels a whole lot better but kinda hoping mine settles down a bit cause being 6'1" I don't need to sit up any higher….
Old May 22, 2014 | 12:40 AM
SG Lou's Avatar
SG Lou
I just did something along the same lines, but for different reasons....
Read on.
http://forums.corvetteforum.com/c5-g...ion-rehab.html
Old May 22, 2014 | 08:38 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
I read yours about a week ago
To lower seat foam install
