Timing Cover Install Question
Old May 16, 2014 | 12:19 PM
RoccoC5's Avatar
RoccoC5
Default Timing Cover Install Question
When installing the timing cover should I use some RTV along the full length of the bottom of the cover, or just the corners where the pan intersects the block? I've read it both ways and want to do it right the first time.
Old May 16, 2014 | 01:51 PM
thumpinc5's Avatar
thumpinc5
I just used it on the corners.
Frank
Old May 16, 2014 | 02:15 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Just the corners. If you do the entire bottom it will probably leak. Don't use a ton and don't use to little.
Old May 16, 2014 | 04:06 PM
RoccoC5's Avatar
RoccoC5
Frank
Great, I'll add a small bead to the corners. Thanks.
To Timing Cover Install Question
