manual fan switch??
Old Jul 21, 2002 | 01:15 PM
tbird's Avatar
tbird
Default manual fan switch??
Anyone know how or where to purchase a manual switch se up that will run both fans on high speed??
Old Jul 21, 2002 | 04:04 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: manual fan switch?? (tbird)
You might do a search on this. There was a recent post where a member gave instructions on a fan switch for about $40 from Pep Boys. The only reason I didn't go with it was because the instructions seemed kind of complicated and needed some soldering.
Old Jul 21, 2002 | 04:12 PM
BlackOps's Avatar
BlackOps
From: Evansville, IN The GOCC, rebels without a clue.
St. Jude Donor '06
I sent you an email with a word doc in it that has what you are looking for, I believe. Another forum member found it and sent it to me.
Old Jul 21, 2002 | 06:27 PM
tbird's Avatar
tbird
Default Re: manual fan switch?? (BlackOps)
Thanks!!!
This looks like what I am looking for. I will give it a try. and Thanks again for the info
Tbird
Old Jul 21, 2002 | 09:45 PM
CP's Avatar
CP
Why don't you post it? Or email it to me
paulgallagher@houston.rr.com
Old Jul 21, 2002 | 09:52 PM
pridnjoy's Avatar
pridnjoy
Cruise-In III Veteran
Default Re: manual fan switch?? (CP)
Please post or post a link if possible. :yesnod:
Old Jul 21, 2002 | 10:11 PM
Jim 47's Avatar
Jim 47
Paul (CP):
I think it is a waste of time to install a manual switch, only because I did it and then decided to reprogram the fans to come on at lower temperatures, which to me is a much better solution to get lower coolant temperatures in the summer.
The manual switch solution wasn't particularly difficult, but it did require taking out the glove box and installing a relay under the dash and running wires through the firewall to the fuse/relay box in front of the battery. In other words a lot of tedious grunt work. All you need is a 30 amp relay, switch with indicator light, a few feet of wire, a fused connection to the fuse pannel in the passenger's foot well, and know what terminals to use on the main fan relay socket. :D Some fun, Ugh??? :)
Old Jul 21, 2002 | 10:17 PM
pridnjoy's Avatar
pridnjoy
Default Re: manual fan switch?? (Jim 47)
I'd love to have mine reprogrammed, but don't know anybody locally that can do that. :nonod: Unless the dealer will?
Old Jul 21, 2002 | 10:45 PM
BlackOps's Avatar
BlackOps
St. Jude Donor '06
CP,
I sent an email to the member that made the fan controller document to ask if he minds if we post it. In the meantime, search the archives for fan controller and you'll find a thread or two about it.
Old Jul 21, 2002 | 10:53 PM
Xssesive's Avatar
Xssesive
Default Re: manual fan switch?? (pridnjoy)
Xtreme Motrsports sells a cooling kit to reset fan temps and includes a 172 degree thermostat for $229. Plugs into exsisting wiring(plug and go) :yesnod:
Old Jul 22, 2002 | 01:28 AM
tbird's Avatar
tbird
If you put in a second switch that direct grounds the two fans you should also have high speed on the fans. The mod gives you both fans on low speed and works fine. I guess you could use a double throw double pole switch and have high and low speed fans ?????
tbird
Old Jul 22, 2002 | 01:43 AM
NJVetteGuy's Avatar
NJVetteGuy
When I have mine at the track, I removed the covers from the relays and I use a matchbook to hold the contacts closed. Works great for cool-down between runs, total cost was ZERO :D
Old Jul 22, 2002 | 02:53 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: manual fan switch?? (NJVetteGuy)
saw 1 in a JEGS catalog :cheers:
Old Jul 22, 2002 | 08:44 AM
Ranger's Avatar
Ranger
NJVetteGuy,
It would be helpful if you would post a few pictures to help us understand your method.
Thanks in advance.
Ranger
To manual fan switch??
