More EBCM problems
Old May 19, 2014 | 08:37 AM
bracketshark's Avatar
bracketshark
Default More EBCM problems
99 FRC throwing code C1225, all lights on dash come on soon as the car is moved. After checking the door and seat wiring harnesses and also the speed sensor wiring, I've moved on to deciding the ECBM was bad on the car. We put a snap-on scan tool on the car and drove it both front speed sensors matched perfectly with absolutely no interruption in communication. There for the replacement EBCM. $1400 later the car still throws the same code, with the same lights illuminating. Where do I go from here? Thanks
Old May 19, 2014 | 09:34 AM
bracketshark
I said the only code in it is 1225C, I used the snap on tool to watch the speed sensors communicate with the EBCM. I'm very aware of how to use the DIC to retrieve the codes in the car and that is where I got this one from. Thanks for any help.
I've been talking with Bill C. concerning this issue, We haven't spoken since the replacement ebcm went in, I'm sure when time permits I'll have some good suggestions, from him, to check out. I've got a spare wheel bearing assembly I might switch the left front out just for practice and eliminate that possibility. Again thanks for all help.
Old May 21, 2014 | 09:46 AM
bracketshark
Come on now I need some help, Bill has been unavailable the last couple of nights for Phone calls. I got a suggestion from the guy I bought the EBCM from that I might need to change the BCM also. any thoughts? Thanks to all.
To More EBCM problems
