C5Z doesn't sit level/won't lower
Old May 19, 2014 | 04:19 PM
jstet003's Avatar
jstet003
1st Gear
Default C5Z doesn't sit level/won't lower
stock suspension c5z06 the driver's side rear sits higher than the passenger rear and lowering it with the stock bolts works on front and passenger rear, but drivers side rear will not sit any lower. Any ideas? I was thinking it may be to shocks since they are 12 years old 50k miles... Running out of ideas. Any help is appreciated..thanks!
Old May 19, 2014 | 04:44 PM
3boystoys's Avatar
3boystoys
Maybe a previous owner tried to lower and got stuck on one side.
Old May 19, 2014 | 11:19 PM
Last C5's Avatar
Last C5
How level is it when your butt is in the seat?
Old May 19, 2014 | 11:22 PM
racebum's Avatar
racebum
a great question, get a buddy to measure of add as much weight as you can to the driver seat and measure. i did mine with 3 - 45lb plates. was all i had so it got me close
also the "threads" turning lowering advice isn't accurate. you have to turn and measure
ideally you want the drivers side to be 1/16th to 1/8th higher than the passenger side
To C5Z doesn't sit level/won't lower
