Input on drive shaft couplers.
So I need some advice. I'm doing a clutch swap and am planning on also replacing the drive shaft couplers, bearings and slinger. I've read pretty much every thread I can find on about couplers and I feel like I'm not anywhere closer to figuring out what to do. I bought a pair of prothane 6 shooters before finding the threads about them falling apart/exploding, and now I'm not sure if I should use them. I've read that it's mainly on cars that are road raced where there's heat build up. I've also read that the more rigid couplers cause increased bearing wear. My car is lightly modded 02 Z06, and will likely get cammed over the winter. I don't road race but I do like to go to the drag strip from time to time. Anyone using them with no problems? Should I send them back and get GM? Or maybe BMW? Can anyone give me some definitive answers? I would definitely appreciate it.
Just did this three weeks ago. I'll update my thread with PNs, prices, and how to this weekend.
http://forums.corvetteforum.com/c5-g...road-trip.html
bottom line I went with GM after reading posts about how the driveline works. Rubber was used to build in some flex into the driveline. There has to be some give somewhere, or the parts have to be engineered a lot firmer.
Solid couplers, in some people's opinion, should be used with strengthened driveline.
Found my post. http://forums.corvetteforum.com/1570047262-post20.html
probably 100 1.6 60' launches.
Dave
Dave
Read this also re: differences in the bmw bushings. German vs. China. http://forums.corvetteforum.com/c5-t...cs-inside.html.
It's been years but I think they're on eBay http://m.ebay.com/itm?itemId=110986726211
