Alignment needed ?
Old May 26, 2014 | 09:42 PM
Darrell98's Avatar
Darrell98
Default Alignment needed ?
I just did C6 Z06 shocks and C6 Z51 sway bars and metal end links on a 1998 Corvette. Purchased from the GM Parts House. Wow! what a difference! Do I need an alignment ?
Old May 26, 2014 | 09:57 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
so long as you did not move the lower control arm bolts where it bolts to the cradle that make the camber/caster adjustments, then no.
Old May 26, 2014 | 10:20 PM
spdislife's Avatar
spdislife
I don't think so. You didn't replace any parts that effect the alignment. I'm sure you'll get some other opinions and then can make a decision as to what's best,
Old May 27, 2014 | 12:08 AM
Smokin Joe's Avatar
Smokin Joe
I recommend change your alignment to Z06 spec. You don't need it now, but considering you just did some handling improvements, you might as well at some point.
To Alignment needed ?
