It is in connector C2 which is the largest of the 3 connectors at the BCM. Here is the pin out for finding the white wire, circuit 193, pin C3. If I can help any more, PM me with your phone number and we can discuss.
If you intend to remove the individual connector pin (female) there is a good how to on any of the LMC5 eBay ads. Nice instructional video. They have not put it on their website yet.
Thanks! That was very helpful. Well I want to cut the 193 wire and run it to ground. I think then when I trigger the rear defroster it will stay on until I turn it off. I think the wiring going to the defroster wires in the window are 12V+. I will need to check. If so then I can use the defroster switch for a 20A circuit already near the rear of the car to run some auxiliary cooler pumps for the rear end. I'm racing. What I also need to find are the orphan wires that used to go to the rear window. I think they used to run up the passenger side under carpet near the door sill.
What you want will not happen if you ground that wire. The defroster will be on whenever the ignition is ON with no control. I think we need to talk. I am sure I can help you achieve your golds. I am going to PM you with my number and we can discuss this if you want.
