I had a shock warning come on and also said to stay under 80 mph!!
The warning has not come back on, does this indicate that I have aproblem with the shocks themselves or the computer? :confused:
Also anyone else have a problem with 1st gear popping out? Is this a problem with linkage or synchros? :mad
If the active handeling computer detects a fault with the shock actuators or suspension ride height sensors, the shock default to the "full soft" setting, and the top speed of the car is limited to 80MPH.
