Rear leak. What do I have here?
Old May 31, 2014 | 12:28 PM
mgmcaleer's Avatar
mgmcaleer
Default Rear leak. What do I have here?
I noticed a spot on my driveway so I lifted the rear and found a leak. Is this an output shaft leak? What am I looking at as far as repairs?
Old May 31, 2014 | 02:00 PM
Zeoohsix's Avatar
Zeoohsix
output shaft and/or the side cover gasket as well. This is the dreaded leaky butt. Did mine last year following the directions on the forum. Not a bad job for a somewhat mechanically involved person. I didn't ever want to track down any more leaks so I pulled the entire rear and did both output shafts and did the 3 O-ring gaskets with the special GM sealant. 15,000 hard miles later and it is still nice and dry.
Old May 31, 2014 | 04:46 PM
dr_whigham's Avatar
dr_whigham
This is a job I DONT look forward to. Mine looks identical.
Old May 31, 2014 | 05:31 PM
78GEN3's Avatar
78GEN3
It's really not too bad to do. I did the same and replaced all seals and o-rings at the same time. I pulled my trans and resealed everything on it as well since I had a seaping trans too.
Old May 31, 2014 | 05:48 PM
StingrayRebel's Avatar
StingrayRebel
that's a bad leak and a lot of fluid lost to just barely notice it
Old Jun 5, 2014 | 05:24 PM
mgmcaleer's Avatar
mgmcaleer
I took it in to 21st Century Muscle Cars in Addison, TX. Matt hooked me up and had the seals changed on both sides.
Old Jun 5, 2014 | 09:49 PM
Chicago1's Avatar
Chicago1
http://www.digitalcorvettes.com/foru...d.php?t=101986
Old Jun 6, 2014 | 08:37 AM
SaberD's Avatar
SaberD
Definitely the side cover gasket, and I would go ahead and do the axle seal while you're at it. Not a bad job. Be prepared to spend $50 on a small tube of the GM anaerobic sealant though.
Old Jun 6, 2014 | 08:41 PM
SG Lou's Avatar
SG Lou
Are you referring to the Shaft Seals? I replaced mine 3 years ago, didn't use the GM anaerobic sealant and it's still dry as a bone in the desert !
Old Jun 7, 2014 | 01:50 AM
Smokin Joe's Avatar
Smokin Joe
front cover gasket 89047954 $8.91 GMPartshouse
output shaft seals (x2) (axle shaft seal?) 88996703 $21.01 GMPartshouse
rear axel "side" seals (x2) (side cover O-ring) 89047953 $52.14 GMPartshouse
add sealant to side cover 1052942 $22.30 GMPartshouse
I just did it.
Old Jun 7, 2014 | 01:54 AM
Chicago1's Avatar
Chicago1
You guys didn't pull the rear diff right? Seen some do some dont
Old Jun 9, 2014 | 02:52 AM
Smokin Joe's Avatar
Smokin Joe
I took the whole car apart. There are 5476 parts in all.
just kidding. I did take the entire drivetrain out. I had to rebuild the dif, open and inspect the trans, rebuild the TT, and replace the clutch.
If you are leaving it in, It may be worthwhile to drop the rear subframe.
Old Jul 21, 2014 | 02:20 PM
whydallas's Avatar
whydallas
MGMCALLER, what did 21st century muscle car charge>>>> I have the same problem and live next to addisom....
Old Jul 21, 2014 | 02:50 PM
BosqueVette98's Avatar
BosqueVette98
A local Chevy dealer just quoted me $2,100 +tax to fix this on mine...
Old Jul 21, 2014 | 04:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
He must be smoking CRACK!
You could get a new rearend for about that!!!
Run FOREST RUN!!!!!!!
Old Jul 21, 2014 | 04:43 PM
StingrayRebel
I'll do it for half of that
To Rear leak. What do I have here?
