i was driving today and out of nowhere my voltage dropped and the dic threw a message saying charge system fault. luckily i was near my house so i made it home on such low voltage, had my alternator tested and it is working fine. are there any fuses i need to check? and where exactly are the grounds related to the charging system.
Any work done recently to affect the starter? May be a loose/bad connection there even if no recent work was done. A fusible link could also explain it.
no stock manifolds. at a glance the starter wires all looked good. battery connections are tight. but im not sure where the grounds are to check or the fusable links. although there was some welding done to the rear frame recently.
I had the same problem (P1637). The alternator checked out good, but after checking everything else. I went back to the alternator (100K+ miles), I found that brushes were almost gone. Changing the brushes and voltage regulator fixed the problem.
Alternator puts out 14.5v on the test bench. In car does nothing. Battery wire and battery showing same voltage bypassing starter has no effect. L terminal has no resistence and is only putting out .8 volts while running. Is pcm fried?
I understand the bench test statement. I do not understand the next two statements. Not enough detail/specifics. What is the L terminal? Does not show on my schematic I provided.
the three terminals on the alternator at the plug are L(generator turn on signal in the schematic you provided ) ,F,and S. from my understanding the L is supposed to be 5v from the ecu to turn on the generator. F is for the pcm to see the alternator duty cycle and S goes to the starter for a 12v always on source. jumpering the S terminal wire to the battery positive post should rule out starter wire. and the L wire ohm'd ok. but while on the L wire (should be 5 volts from what iv read) is only putting out .85v
never would have thought this but after testing the alternator again and having it pass, i checking everything again so i decided to just try another alternator and low and behold that solved it. no clue why but ill take what i can get
