Any harm in a 160 degree stat?
As for harming your engine, no, it won't. You may see earlier oil changes suggested from the DIC due to lower oil temps, but most people change oil sooner anyway. :cool:
[Modified by jimman, 2:06 AM 7/23/2002]
It's bad for your engine in several ways: 1) running rich can flush lubricant from cylinder walls, resulting in poor lubrication, 2) current oils are meant to run hot, 220 F and more, so they burn off any fuel/other impurities, lower thermostats will not let you burn off these, this results in poor lubrication, 3) engines are designed to run at certain temperatures, with tolorances, running at other temperatures is not optimum (especially true with an aluminum engine), this is one reason they tell you to wait until your car is warmed up before "getting on it", with a lower thermostat you're never warmed up, 4) varible weight oils (i.e. 10W-30, thicken as the temperature rises, run them cooler and they are thinner, with less protection.
Of course running more horsepower with less lubrication is a prescription for trouble.
Lower temps, but above 160 should give you a better average power rating with a smoother power curve.
I prefer the lower temps. Better for the engine too.
in the 2000 Corvette (Y-Platform) service manual: Volume 2, page 6-560
Under: Conditons for Setting the DTC (this is for related diagnostics when looking for Engine Coolant Temperature (ETC) Excessive Time to Closed Loop Fuel Control). "The Closed Loop coolant temperature of 34 degrees C (93 degrees F) is not reached in a predetermined time" (referring to when it sets the DTC code) The normal time from a cold start to closed loop temperature is 5 minutes, less when the engine is already warmed up some...
'nuff said
:cheers:
As far as the strip is concerned to many variables to make any acurate analysis, like track conditions, tire temps, shift points, the list goes on. I ran six runs last month and there was delta of .6 seconds between them. The dyno run was within minutes and no variables other than temp. I guess I've been an engineer to long, I'm just stuck on controled tests and there results vs a lets give it another shot.
[Modified by jimman, 1:07 AM 7/25/2002]
Did you REALLY do SIX dyno runs with the ONLY variable being the coolant temp? :eek: If so, what did they show? How much HP change did you see? Was the change in HP above or below the accuracy level of the equipment? Did you order the tests properly (hot, cold, hot, cold, hot, cold) and did you get repeatability of the data? I'm not gonna throw the BS flag, but you're the first I've seen to claim to test this (hopefully) the right way. :cool:
He has a web site that he posts the results. We get a ton of guys and it's quite informative. The hp gain or loss is really insignificant when the temps are varied. What is interesting is the erratic nature of the curve at cold temps. It takes the 3rd pull to get a clean line when you go in with a room temp car. We all now prewarm to get the best performance. My 00 was best over 200. I just did my 02 and I just now run the temp up so I dont waste a pull, His web site is, http://forums.corvetteforum.com/zerothread?id=304821
I would post the graphs but I can't even get the web site to do my sig photo let alone anything else.
From the same service manual, volume 2, page 6-1207
"Run Mode:
The run mode has 2 conditions called Open Loop and Closed Loop. When the engine is first started, and the engine speed is above a predetermined RPM, the system begins Open Loop operation. The PCM ignores the signal from the HO2S and calculates the air/fuel ratio based on the inputs from the ECT, MAF, MAP, and TP sensors. The system stays in Open Loop until meeting the following conditions:
*Both HO2S have varying voltage output, showing that they are hot enough to operate properly. This depends upon the engine temperature.
*The ECT sensor is above a specified temperature.
*A specific amount of time has elapsed after starting the engine.
Specific values for the above conditions exist for each different engine, and are stored in the electrically erasable programmable read only memory (EEPROM). The system begins Closed Loop operation after reaching these values. In Closed Loop, the PCM calculates the air/fuel ratio (injector on-time) based on the signal from various sensors, but mainly from the HO2S. This allows the air/fuel ratio to stay very close to 14.7:1."
Now if I'm not mistaken, my first quote included the reference to the ECT (Engine Coolant Temperature). Being that this is one of the criteria listed above, and that closed loop coolant temperature is (34 degrees C) or (93 degrees F), I don't know why you fail to see the association.
Now, at your suggestion, I have tried to continue to research this issue, and nowhere can I find a reference to idle reset procdure and closed or open loop.
I'm not an engineer but I do own my own business and in my world you provide resource data to back up what you say as fact. I have provided you with two references for my data. Could you point me in the correct direction to support your claim of 176 degrees F being the Closed Loop temperature because of the idle reset procedure???? :confused:
I'll withhold my use of :bs until I see you don't provide the requested information.
Thanks in advance.
At <225° temp, the pulls were 361, 359. When the coolant reached 225° the HP dropped DURING the dyno run like a switch was thrown, and achieved 343hp. The 359 pull was first, then the 343, last the 361. The 359 and 361 pulls were started at the same water temp and air temp.
This is bone stock.
I did alot of dyno testing on my LS1 engine. What I found: Water temps between 174-200 had little effect on output. Above that, and below that effects the output. Over 225 CREAMS it. This is the range that a 160° therm puts you in. ALWAYS thrash on your car prior to tieing down. Get up to operating temp, then go WOT several times. Then tie down. This adjusts your PCM for maximum performance. Don't believe it? Try it.
