3 Questions for the Tech Guys..IDK
Old Jun 5, 2014 | 09:37 PM
SaxyVette's Avatar
SaxyVette
Default 3 Questions for the Tech Guys..IDK
Just got a used '99 a/t coupe w/ 220+ miles on the clock..it's on the rack at a shop getting a new trans installed.
1) While on the rack, should I have them check the Differential Oil/grease, and add or replace?
2) after I get it home..what is the best standard procedure for flushing the cooling system (maybe a DIY ? or.. should I get a good shop to do it right?)
3) I know I'll get an oil change right away ASAP (Mobil 1 synthetic , I think..) then top off brake/PS fluids if needed.
I need to keep my costs to a bare minimum as I blew my wad on the downpayment.
Thanks guys it's my first C5 and I'm stoked !!
Old Jun 5, 2014 | 11:46 PM
jcgunn's Avatar
jcgunn
Absolutely, positively have all of the fluids replaced if you can't verify when they were changed.
Old Jun 6, 2014 | 12:01 AM
SaxyVette's Avatar
SaxyVette
JC I absolutely agree with you. Prob is I can't afford to do everything all at once..I have to start in steps and Oil and Water will be first. My brakes and steering seemed OK for the little bit I drove the car..
But, I know I will need to check ALL fluids asap to make sure levels are correct and plan to do it all as soon as possible.
The flush deal is a precaution with the hot summer Vegas Heat where I live. Not sure if I'm qualified to do a real flush in my driveway.
If not I'll be squirlling away some extra coin to have a pro do it right.
Oil change will likely be the most important step #1 ..I'll find a good outfit for that job. I need to get the very best Oil for the Vegas Temps and my High miles engine. I've read Mobil 1 synthetic but I'm not an expert on oil..
I really appreciate your input..Thanks!
Old Jun 6, 2014 | 02:24 PM
Jims79's Avatar
Jims79
Welcome to the club, don't forget to wave. Your on the right track, change the oil first Mobil 1 makes a high mileage I would use it. Check & top off all other fluids for now. Change each on down the road. Good luck w/her. Oh you better post pic's or get flogged for not doing so.
Old Jun 6, 2014 | 04:09 PM
oh1vette's Avatar
oh1vette
The "Sticky" thread at the top of this page has a ton of DIY how tos...check it out, may be able to save some cash doing the easy ones yourself
http://forums.corvetteforum.com/c5-t...l-in-here.html
Old Jun 6, 2014 | 06:27 PM
SaxyVette's Avatar
SaxyVette
Thanks guys I will be checking out a lot of the sticky's for sure. You can see complete pics of my car so far at the trans shop. Check out:
"Low buck C5's how the other half lives" and "My C5 first Pics" by Saxyvette
To 3 Questions for the Tech Guys..IDK
