Gear Ratios
Old Aug 26, 2010 | 04:25 PM
ljorges's Avatar
ljorges
Default Gear Ratios
Sorry for the noob question but after reading many posts, I see references to gear ratios. Don't really need a super detailed explanation but I want to know what effect it has on performance.
I was looking at the build sheet for my 03 AE 6sp Vert and it said it had a rear axle 3.42. Is that good, bad?
Just trying to get in touch with my inner vette-ness and not sound like a total dweeb when talking to friends about my newly acquired baby.
Thanks,
Les
Old Aug 26, 2010 | 05:41 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Thanks,
Les
Well you have a nice rear ratio right now. The higher the number
the mpg will be less. If you had a 273 your mpg would be better.
Higher numbers are really for 1/4 mile folks and dont worry about
that. If you are interested in this there is lots of reading material.
Use your computer or library and you will learn all about how to be a
1/4 mile (or 1/8) racer. Good luck.
I am sure some else will help me out trying to explain this
complicated subject in a couple of sentences. Sometimes I know
to much for my own good.
Old Aug 26, 2010 | 07:44 PM
craig04c5's Avatar
craig04c5
Your 3:42 is the standard gear ratio for a 6 speed transmission. It is great for fuel consumption but leaves a lot to be desired for performance. C5's with the Z51 performance option has a different transmission gear ratio but the rear is still a 3:42. That gearing is better in gears 1 and 2 and maybe 3 (not sure) but about the same as non Z51 in other gears. Many C5 owners change the differential to 3:90 or 4:10's for better performance. The cost in fuel consumption is about 2 mpg but the performance gain is about 1/2 second in the 1/4 mile. It is also much nicer to drive with the performance gears. There is no bogging, or clutch noise when taking off and the power is immediate. You also use 6th gear in everyday driving. I usually use 1, 3 and 5th or 6th in normal driving with my 4:10's. Also I take off from 2nd if not completely stopped.
Old Aug 26, 2010 | 08:27 PM
2KFRC5's Avatar
2KFRC5
I thought the Z51 with the manual has the same transmission ratios as the non-Z51 manual. It's the Z06 that has the different tranny ratios.
The Z51 with the auto comes with the 3.15 RE vs the standard 2.73 RE on the non Z51 autos.
Old Aug 26, 2010 | 08:46 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
this is correct.
OP,
The only gear available in a manual trans vette is the 3.42
The auto cars had either a 2.73 or a 3.15
The higher the number the lower the gearing of the fiinal drive and the easier it is to start from a stop - this is why drag racers like 3.90 and 4.10 gears - as mentioned above.
Gas mileage will suffer from changing gears - some (like me) dont care, and just love the way the car responds on the street and the track.
Changing the gear is available in basically two ways,
buying a complete differential, or
having a set installed in your differential.
The swap can be done in a day by an experienced installer.
Good luck, welcome to the C5 vette world. Feel free to ask any questions here, as there are a lot of very smart people here
Old Aug 27, 2010 | 08:32 AM
AU N EGL's Avatar
AU N EGL
for 6 speed manual, the 3.42 is optimal
now if your into serious drag racing, then a 4.10 or 3.90
Old Aug 27, 2010 | 09:05 AM
99 vett babycar's Avatar
99 vett babycar
342 is GOOD
Old Aug 27, 2010 | 10:18 AM
HP_Addict's Avatar
HP_Addict
like they said the 3.42 is the stock gear with a 6speed. It is a good all around gear. However many people change to a 3.73, 3.90, or 4.10. These gears provide better acceleration with slightly worse gas mileage. Many people overlook gears when seeking better performance, yet it is arguably the one area where you can get the most gain. 3.73s or 3.90s make the car drive completely different. Its a great mod.
Old Aug 28, 2010 | 07:29 AM
danberry's Avatar
danberry
Compare here
Old Aug 29, 2010 | 02:10 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Other issues to consider when going lower than the stock 3.42's
Lower gears will make the car launch very hard---traction becomes an issue--often you won't pick up much ET's without getting drag radials becuase the car just spins more--
Also lower gears will "shock" the drivetrain more--at launch--things are more suspect to breaking---usually the output shafts will break and you'll have to install meaner aftermarket ones--more $$$ --- If your car is hopping when lauched you WILL break them sooner or later---tell tale sign--
Old Aug 29, 2010 | 04:19 PM
David426's Avatar
David426
The Z51 performance option does not offer a different transmission with different ratios.. The M6 manual is the same in all C5's The Z06 has an M12 transmission with a 3.42 axle ratio. This is the transmission with better (more aggresive) gearing in gears 1-3.. Again this transmission (M12) is exclusive to only the Z06 and was the only transmission available in a Z06.. The (M6) 6 speed was put in all other C5 Corvettes regardless of option packages.
Old Jul 29, 2011 | 07:14 PM
stevec's Avatar
stevec
Originally Posted by Capthuff
this is correct.
OP,
I was told by a mechanic that changing gears from a 2.73 to a 3.15 or 3.42 would require removing both the diff and axle. Is this true?
Old Jul 29, 2011 | 07:19 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
yes.
When changing the gear ratio in the differential on a C5 corvette, the rear cradle has to come out of the car. As does the exhaust h-pipe (or x-pipe) and the tunnel plate.
The axles slide out of the differential and the differential unbolts from the transmission. Then the shop (I hope you chose a good one) takes the diff apart and installs your new ring and pinion.
It's not really an "easy" job, but not really hard either - it just takes time. Which is why you can save a bit of money by taking the diff out yourself and bringing it to a shop to be built.
Old Jul 29, 2011 | 08:09 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
The M12 transmission option was only available on the Z06.
http://www.c5registry.com/zo6/hib/page4.htm
Old Jul 29, 2011 | 10:39 PM
f6john's Avatar
f6john
It's sometimes amazing to me that info is posted on the "tech" board that is just incorrect. To make statements on the general board where discussion is often opinion, the occasional slip of a more technical nature is not all that uncommon. But to me, if you are going to post on the tech board you should either know what you're talking about or preface your statements with, I believe, I'm pretty sure, or I could be mistaken but.....
I am far from an expert in all things Corvette and I learn more every day much of it gleaned from these forums. There is a wealth of knowledge to be shared by everyone but it behooves us to have our facts straight if we are going to present them as such. Now down from my soapbox and back to the cheap seats.
Old Jul 30, 2011 | 08:37 AM
craig04c5's Avatar
craig04c5
Yes, my bad. Brain fart. I edited my post meant to refer to Z06 with
M12 transmission.
Old Jun 5, 2014 | 11:07 AM
dgoff's Avatar
dgoff
Default Does the 1999 FRC have a MN6 or a M12 transmission
I have looked over this forum for hours. It seems every question about trans. Ends up talking about C5 vs. Z06 and rear end ratios. I can't find anything about identify casting numbers etc.. Can you help?
Don
Old Jun 6, 2014 | 07:35 PM
PRE-Z06's Avatar
PRE-Z06
Don
The FRC has the same trans gear ratios as the base C5, not the C5Z ratios that are also in the GTO.
To Gear Ratios
