I had the gas gauge dropping to zero problem last year and had the right side siphon jet and fuel sending unit replaced which cured the problem. When I filled the gas tank today, I got 6 gallons in and it took me about 10 minutes to get in the other 9 gallons. This was the first time that happened. I've been putting a bottle of Techron in the tank every 4th fill-up as a precaution. When I got home, I pulled the codes and this is what I found:
28 TCS U1016H
Radio U1016H
AO LDCM U1255H, U1064H, U1016H, U1096H
A1 RDCM U1255H, U1064H, U1016H, U1096H
When I looked these up, I found that these are Loss of Communication codes. What does that really mean? As far as I can tell, the car seems to drive fine and operate normally (other than having a difficult time filling the gas tank today). Any help?
OK, dumb question time: I didn't have any trouble taking off the nut that holds the ground connections to the frame, but how do you get the connector apart? On one side of the connector, it looked like there was a small tab that I could push in with a little screw driver but I didn't see anything on the other side. I really don't want to break anything.
I used small flat head actually 2 of them and a lot of prying up and pushing the tab in.
Check the ground in the Passenger door. Their is a board out their, It took 6 hours for the guys at Chevy to fine it for me 10 years ago. it is the DCM.
You can look for more than 6 hours but there is NO ground in the door.
