Ok,
I know this is a common problem and searched threads for some answers .
I have LS6 with catch can pulled off TB to clean and puddle of oil sitting inside intake ?
Cleaned it out drove a few miles more oil in intake ?
Car runs fine no puffs of oil spark plugs are clean What gives ?
I do have after market Valve covers but all PVC line are hooked up and working .
Should I be worried about this ?
what kind of catch can do you have?... some of them are not designed properly and are really no more than an empty can and can easily allow oil to pass right through and back into your intake
That is the can I have . My friend with a Ls3 has same one works great .i made sure it was connected correct . But I dont have the valve cover vents Y off to the can .
My pass side valve cover vent is connected to top of TB on right side ?
Guess you found your oil source.
You need to "Y" then together or run two catch cans.
I was thinking the PCV, but is it before or after the catch can? The reason I ask is, the blow-by that occurs may still by causing some oil from the catch can to cycle into the intake. Also, is do you have any codes where the throttle position sensor can be off? I am thinking of an issue where a positive pressure is being built and forcing a blow back into the intake...
Factory valve covers have baffles inside them that help to keep oil away from the hose connections.
Without the baffles, oil has a direct shot at the hose.
Your link to the covers brought up this thread.....
Aftermarket covers often times have no baffles......so you should check for that
There is no other line coming from VC but the fresh air line from top right side of TB . I checked my OEM VC's same thing , the drives side cover has NO line coming off of it . I have line from Vally cover running to Catch Can out Catch can to TB thats it there is no other lines to "Y" to Catch Can ? I did read that on 2004 LS6 and up GM has a up dated Valley Cover with internal PVC ?
Attached is my set up .
ps, the after market VC have baffles
