Camshaft question
Old Jun 10, 2014 | 09:26 AM
smask04c5's Avatar
smask04c5
Default Camshaft question
Installed a Comp cam, .614/.617 227/231 lsl lobes on a 383 with AFR 215's, Fast 102 and NW 102 TB. Any issues if I decided to run 1.8 ratio rockers? Theoretical lift in the .650 range Thanks
Old Jun 10, 2014 | 03:14 PM
tlove32's Avatar
tlove32
You''d have to check piston-to-valve clearance to be 100% sure of no issues. Also, there might be an issue with too much lift for the valve springs.
Old Jun 10, 2014 | 10:17 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
His 383 is likely to have valve reliefs, but most ptv would be from larger intake duration or a the LSA and ICL of the cam. Not due to more lift with the rockers. Most companies wont recommend using 1.8s but I say go with what you want, but buy a quality rocker and make sure you have a decent set of springs for them.
To Camshaft question
