Reverse Lockout Solenoid Question
Old Jun 13, 2014 | 08:06 AM
Macleod52's Avatar
Macleod52
Default Reverse Lockout Solenoid Question
I just purchased a new reverse lockout solenoid (AC Delco 19178634). With no voltage applied I can freely push in the pin. I was reading a few posts and I thought I read that it should only push in when voltage is applied. Is this correct? Do I have a bad unit?
Old Jun 13, 2014 | 08:37 AM
dadaroo's Avatar
dadaroo
When voltage is applied (above 3mph) the solenoid is energized to prevent going into reverse.
If you apply voltage to it I bet the pin will extend outward. Does not matter which pin has + or - applied.
Old Jun 13, 2014 | 08:54 AM
Macleod52's Avatar
Macleod52
Thanks. I'll give it a try.
To Reverse Lockout Solenoid Question
