Key FOB problem - help
Old Jun 13, 2014 | 04:19 PM
dkw's Avatar
dkw
Default Key FOB problem - help
So, both key fob batteries were dead, so replaced. Reprogrammed both and both will lock and unlock the doors. However, after a short period the horn will beep every 10 - 15 seconds. I did try the solder trick and did the points as shown in the fix - still beeps. Only way to stop it is to take the batteries out of the fob.
Any help, suggestions appreciated. It is a 1999 with the original fobs.
Old Jun 13, 2014 | 07:55 PM
HardcoreABN's Avatar
HardcoreABN
8VETTE7 I LOVE your hood
Old Jun 14, 2014 | 09:59 AM
helga203's Avatar
helga203
Holy moley this just happen to me. Im going to try this and see what happens.
Old Jun 14, 2014 | 10:13 AM
helga203's Avatar
helga203
Default Fob
OOOMMMGGG It worked both my fobs were freaking out. The batties went dead last october, november. Car was down for repairs. About a two weeks ago replaced batteries om both fobs and by pass was doing wath you decribed. But tried your method of switching on off, on off several times and both work now. Thank you 8vette7:w illy::thumbs :
Old Jun 14, 2014 | 10:25 PM
dkw's Avatar
dkw
Default Key fob
Originally Posted by 8VETTE7
Sounds like the legendary "passive" feature is causing the problem. Have you tried taking the fob completely apart and cleaning the pocket lint from around the passive button? Also sliding the passive button back and forth a few dozen times sometimes helps.
GM stopped making that function in 2000 because it was such a POS.
Thanks. Have not had a chance to try this yet but will ASAP. Will post results.
To Key FOB problem - help
