c5 fluid change interval (time) advice
also seeing many with original dexcool after 11+ years understand not as critical and can be tested but oil advice would be appreciated.
I made this mistake on my first differential oil change, and my symptoms were exactly as you described. Before you have the seal(s) changed, try this procedure. It worked for me.
To the original poster - I'd be more worried about brake fluid (brakes and clutch) than anything else. Brake fluid picks up water from the atmosphere, not only lowing the boiling point, but allowing the master and wheel cyllinders to rust. Look at the color of the brake and clutch fluid in the reservoirs. If they're clear, you're probably OK. If they're the color of Coca Cola, that's a bad sign and you may need to replace master, slave and wheel cyllinders - not cheap.
For synthetic motor oil, many manufacturers (Porsche, specifically) recomends a 12-month oil change interval. The main concern you'd have with a longer interval would be acidification of the oil, more likely due to short driving periods and the oil not getting hot enough than just low mileage. If, when it was driven, it wasn't just driven a mile to the grocery store and back, 2 years is probably OK. You can have the oil tested if it really concerns you.
For coolant, if the Dexcool is original, the corrosion-preventive additives are long-gone. You may have some internal corrosion that you can't see, but it's probably not too bad if the car doesn't over-heat. I'd get that changed as well - but not worry too much if the car stays relatively cool in high-load and low-speed conditions.
