Hello all. New to me 03 Z and when I slowly go around a right hand turn I hear a rumble coming form the right rear in the trunk area. Sounds like rocks moving around. Somewhere I read in a thread about it could possibly be the rear gear oil??? Anyone have a similar issue??
Possibly the previous owner used it to haul gravel?
One thing you might check is the wheel to see if it has cracks and making a noise during the bind of the turn. Hard to diagnose a noise without hearing it.
Ok, I hear it inside the car coming from the trunk area. Right turn only and slow speed. Nothing turning left. Sounds like a muffled metallic rattle. Nothing is loose underneath...shock mount, exhaust, torqued wheels. Could this be the diff?
Originally Posted by Smokin Joe
Umm... I need a little more then a rumble and rocks description. Rumble...maybe a good exhaust catback? Rocks...anything loose in the trunk?
Seriously, though, give me some more. Where do you hear it? When do you hear it? Inside? Outside the car?
I was hoping this might be similar to my case: going around a corner, I hear what sounds like a nut or a bolt rolling inside a channel from one side to the other, can't figure it out. If I turn left, it rolls to the right side; if I turn right, it rolls to the left side. No clue and I can't find anything obvious.
Wheel lock socket that is under the hatch carpet on the driver's
side in an indented channel maybe? Probably not, but it might be
worth checking.
