Leaking Fuel sending ubit
Old Jun 17, 2014 | 12:39 PM
TacDoc's Avatar
TacDoc
Default Leaking Fuel sending ubit
Smelling gas so lifted car, leaking around o-ring of electrical connector of fuel sending unit (LH). Anyone ever replaced this o ring. A new unit is $$$.
Old Jun 17, 2014 | 05:47 PM
Chicago1's Avatar
Chicago1
The oring around the hat is that what you are talking about? If so yes you can replace that you will just have to drain the gas. take the liner off loosen the 3 fuel lines and connector take the 6 or so bolts catch whatever gas is left take the old one off put the new one in. they are 30-50 bucks
Old Jun 18, 2014 | 07:31 AM
TacDoc's Avatar
TacDoc
Unfortunately the leak is the o ring around the electrical connector that is in the center of the aluminum hat.
To Leaking Fuel sending ubit
