Starter Install
Old Jun 18, 2014 | 01:03 PM
RogerZ06's Avatar
RogerZ06
Default Starter Install
I'm installing new starter today also installing new 02 sensors as well.
Should I replace crankshaft position sensor since starter is coming out ?
This guy mentions it in his install.
Old Jun 18, 2014 | 02:00 PM
Blow Torch's Avatar
Blow Torch
I personally wouldn't. Mine is over 12 yrs old and no issues. I may not have kept up, but I haven't heard of them having a big failure rate.
Old Jun 18, 2014 | 02:25 PM
dadaroo's Avatar
dadaroo
I hope you are installing a 2 long bolt starter.
Old Jun 18, 2014 | 02:45 PM
RogerZ06's Avatar
RogerZ06
I bought Tuff stuff starter from summit racing.
http://www.summitracing.com/nv/parts...492b/overview/
Says it comes with two long mounting bolts.
Old Jun 18, 2014 | 03:52 PM
LoneStarFRC's Avatar
LoneStarFRC
It's a very robust part. No moving parts, etc.
Old Jun 19, 2014 | 01:29 AM
reactor2's Avatar
reactor2
The CPS is a bit of a pain in the **** to get to.
1)put car on jack stands
2)shoulder walk in under the car
3)realize you left the tools on the bench
4)drop the eff bomb a few times
5)shoulder walk out
6)shoulder walk back into position
7)remove H pipe
8)remove O2 sensor (it hard to remove the wires on the solenoid with the O2 sensor in the way...for me it is anyway)
9)remove starter
Since you won't be in there often, might as well freshen up the CPS...do you really want to go back in there if it fails?
Old Jun 19, 2014 | 11:18 AM
ggroller's Avatar
ggroller
5)shoulder walk out
7)remove H pipe
9)remove starter
LOL....too true
To Starter Install
