Turns off
Old Jun 19, 2014 | 01:24 PM
mmartinez's Avatar
mmartinez
Default Turns off
This has happened a few times, latest was this morning, car suddenly turns off, the chime sounds and I have to re-start. I have no messages on the DIC, and I have not pulled codes yet. Just wondering if anybody has had this happen to them, its a 1997, any input appreciated.
Old Jun 19, 2014 | 01:48 PM
3boystoys's Avatar
3boystoys
Let's see, only several HUNDRED possibilities with no diagnostics from you on a 17yr old car. You need to do at least SOME legwork here.
Old Jun 19, 2014 | 02:12 PM
mmartinez's Avatar
mmartinez
Default Turns off
Just finished checking codes, no current codes only two history codes showing on the DIC. Could I have a oil pressure sensor dropping out indicating no oil pressure, battery is optima Red Top which came with the car when I bought it some 8 years ago, but has not given me any problems. Thanks Guys.
Old Jun 19, 2014 | 02:18 PM
3boystoys's Avatar
3boystoys
If you had no oil pressure you would know in short order. You need to check basics like fuel pressure. What are the 2 code you do get?
Old Jun 19, 2014 | 02:35 PM
mmartinez's Avatar
mmartinez
Default Turns off
My lunch hour here at work is over, I will have get back on line latter. Thanks for your help. Regards
Old Jun 19, 2014 | 05:11 PM
BigGun's Avatar
BigGun
Had any work done on the car lately?
Old Jun 19, 2014 | 05:31 PM
mmartinez's Avatar
mmartinez
Default Turns off
No work done.
Old Jun 19, 2014 | 11:06 PM
corvette77's Avatar
corvette77
Have you had any issues with it starting? Do the guages sweep correctly when you start it? Mine shut off on me last week, and I believe it was related to the ignition switch.
Old Jun 20, 2014 | 12:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
8 Year old RED TOP????? Good luck brother. Ive see older batteries work well in other cars but,,, your C5 is VERY sensitive to low voltage.
Have the battery FULLY TESTED. If it has poor CCA and Reserve capacity, replace it!
YES,, the TAC modules in 97 & early 98 C5s were known to be weak. The one in my 98 failed. When the car DIES,, without doing anything to the ignirion switch, clear any messages and read the codes.
The Ignition Switch can also cause the same issues. KNOWN C5 issue.
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Loose battery terninals.. They MUST be properly torqued to 11 ft/lbs!!!!
Bill
Old Jun 24, 2014 | 12:21 PM
mmartinez's Avatar
mmartinez
Default Turns off
Thanks for the help, I have written down the codes, but they are at home and I am at work today, I also cleared all the codes so next time it happens I can write them down before re-starting. The three times it's happened was while I was slowing down approaching a stop sign, maybe that's a clue, anyway I am planning on buying a new battery this weekend. I will re-post with codes when this happens again if the new battery dos not correct the problem, again thanks for your advise. Regards; Marty
Old Jun 24, 2014 | 12:36 PM
Chicago1's Avatar
Chicago1
Without the codes we are all just shooting in the dark. Help us help you..Are you on TSC..
To Turns off
