abs issues
Old Jun 21, 2014 | 06:37 PM
c7rvette's Avatar
c7rvette
Default abs issues
hi gang, just curious what some of you experts think, like a moron I removed the abs pump...cause the module needed service...anyways, I had the abs fixer service the module...then installed the pump and bled the brakes...now its throwing codes....service abs and service traction control...any suggestions? thanks in advance!!
Old Jun 21, 2014 | 09:28 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
What codes? Did you use a scanner to run the auto bleed procedure prior to bleeding at the wheel?
Old Jun 23, 2014 | 09:28 AM
3boystoys's Avatar
3boystoys
You removed the entire pump or just the EBCM?? If you removed the entire thing, you'll need a flatbed to the dealer.
To abs issues
