Old Run Flat Tire Question
Old Jun 25, 2014 | 04:50 PM
DWMJr's Avatar
DWMJr
Default Old Run Flat Tire Question
Hello, my name is Don I this is my first post as well as my first Corvette. I just bought a 2004 convertible with just over 11,000 miles on it and the run flat tires are original to the car. I have very carefully inspected each tire and I cannot see any crazing or any other visible issues with any of the tires. My question is: What would you do to ensure these tires are safe? Any suggestions would be greatly appreciated. Thank you
Old Jun 25, 2014 | 05:19 PM
Corvette_Ed's Avatar
Corvette_Ed
The tires are not safe; no tire is safe after a decade and the run flats even less because they become extremely hard and, from personal experience, cause wheel hop that could send you into a retaining wall. You should replace them soon.
Old Jun 25, 2014 | 08:42 PM
norcalace's Avatar
norcalace
WHY ISN’T TREAD WEAR THE ONLY FACTOR TO CONSIDER?
In determining whether to replace a tire, consumers should focus on the age of their tires in addition to other factors, such as tread wear.
A tire’s tread depth is measured in 32nds of an inch. Most tires are replaced when a tire has exceeded its useful tread life; approximately 2/32nd of an inch in tread depth remaining. At this point, most consider the tire “worn” and decide it is time to buy new tires.
Unfortunately, we routinely see tire failures on tires that are more than ten years old. These tires have either been installed on automobiles that maintain low mileage on a yearly basis or the tire may have been installed as a spare for several years prior to being placed into service.
By simply looking at the tread wear of a tire, you may not realize that the tire is older and has thus been exposed to prolonged periods of heat and oxygen, decomposing the tire’s internal adhesion over time. Even if the tire has never been used and still has 100% of its tread life remaining, the tire could impose a significant safety risk if the tire is old. The tire’s age, therefore, must not be ignored.
Old Jun 25, 2014 | 08:48 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
No way I would drive on those tires...
Old Jun 26, 2014 | 10:05 AM
3boystoys's Avatar
3boystoys
I think the age issue on many of our cars is overblown. Many of them sit in the garage out of the direct sun and don't see the harsh elements many of our daily drivers do. I finally had to change mine when I noticed the inside of the front tires were getting a little worn from the factory alignment settings.
Old Jun 26, 2014 | 10:18 AM
Ron C!'s Avatar
Ron C!
From NHTSB:
Tire Aging
•• Any rubber begins to break down over time. Heat accelerates this process. The rubber in your tires also breaks down over time, a process referred to as tire aging.
•• Even though a tire may have a lot of remaining tread, its integrity may be compromised. The effect of aging may not be visibly detectable.
•• Tires age whether they are driven on or not and are a concern for infrequently used vehicles and spare tires.
•• An analysis of crashes in the National Automotive Sampling System from 2005-2007 estimates that 90 people die and an additional 3,200 are injured each year in crashes in which tire aging was a factor (http://www.scribd.com/doc/137377038/...-on-tire-aging).
•• As tires age, they are more prone to failure.
•• Some tire manufacturers recommend replacing tires that are 6 to 10 years old, regardless of tread wear.
To Old Run Flat Tire Question
